View Charging Speed
babgvant
Andrew
Chicago
Mach-E GT PE
Software Developer
Other than using an ODBII device + mobile device, is there a way to see what the charging speed is on the Mach-E? Planning to do some traveling in the next few weeks, and according to PlugShare several of the L2 locations with J1772 and Tesla Destination chargers offer higher Tesla charging kW. Would be great to be able to verify that, and roll with whichever has the higher rate.
I already have a ODBII dongle, just wondering if there was an easier way.
Thanks
Brutakus
Vancouver WA
Star White Mach-E Select AWD Comfort/Tech Package
Hopefully Ford does an update that lets us see more info in general but until then, I believe your options are either Electrify America which shows current charge speed on station and in app or you can just do OBD-II
Not to my knowledge. I assume you have a Tesla adapter?
I'm headed out soon, and will be using an app.
back_at_it_19
Seattle area
'21 Job 1 GB FE and '22 Red Prem4x
fwiw the Ford Pass app shows an estimated time to charge (100% or 80% or other depending on charger and your settings). Not quite a speed measurement but close.
babgvant
babgvant
Andrew
Chicago
Mach-E GT PE
Software Developer
Bummer. Yep, bought the Lectron 48A adapter.
santa fe,nm
www.envirokarma.org
Solar Sales/install
Thanks
nope, no easy way to see charge current, output or regen power 'realtime' other than ODB2 and App to display.
It's been suggested as a Display enhancement, but no response from Ford regarding consideration or implementation.
