Too complicated for the average conversation.When someone asks me - How many miles to the gallon do you get?
My answer is
Gas is now 2.99
My electric off peak is .08473 (NC)
I get 4 miles per kw
So that would mean 2.99 divide by .08473 = 35.288
Then multiply 35.288 by 4 = 141.152
or even
Then multiply 35.288 by 3 = 105.864
My answer is how many mpg does your car get? 30
Well for that same price of gas I get between 105 to 141 miles.
You should read up on accounting & amortization.I drop those out because in my case it there are $14 in facility charges but I pay that to have electricity to the house so the only amount that is relevant is the rate at night when I charge.
Depends on how much city vs. highway driving you do. My 'normal' driving (mix of highway commuting and driving kids around town) has averaged around 4.8 in the summer and 4.4 so far this winter. Also, SR battery and RWD will do better than an ER/AWD vehicle due to less weight.How are you getting 4 miles per kw?
Best I can do is 3.3 I'm in a premium extended battery awd
Yeah, on that same note I like to bring up that even if I do spend "time" charging on a road trip, on an annual basis it waaaaaaay less than the time I spend driving to or at gas stations. Right now we have an F-150 PowerBoost and the Mach-e.Do you "spend a lot of time charging" your cell phone? No, you do it at night, usually. Same with the car. But if you go, say, on vacation, and you're going to use your phone more, you might need to find a way to charge middle of the day. Same with the car. But that's the exception, not the rule.
That's been my approach with my family. I then give them some examples of trips we might take, and that for those, charging is optional and only for convenience rather than need.
As for the cost, I tell them that it's costing about $6.50 to run the car for a week.
I like to explain that the time you skip going to gas stations you are 'banking' and then you spend that time when you need to road trip it. Some people, like you and me, are going to come out WAY ahead in that equation.Yeah, on that same note I like to bring up that even if I do spend "time" charging on a road trip, on an annual basis it waaaaaaay less than the time I spend driving to or at gas stations. Right now we have an F-150 PowerBoost and the Mach-e.
Okay don't really need a**hole replies like that. You should probably do a little more research into marginal costs and allocation. The point I was making is the $14 facilities charge is there whether I use 1 kWh or 1000 kWh so that is not relevant to the cost of adding the ~446 kWh of use I consume on an average month. If you want to allocate or amortize that over the whole amount so be it but in the discussion of what my fuel costs are versus my ICE vehicles it is definitely irrelevant.You should read up on accounting & amortization.
If you want to charge at home you need an account with your power company, so all those fees and charges should be allocated to your EV fuel cost using your logic. BTW, just as easy to call the kW for your lights the marginal units consumed as it is to say the KW to power your car. At least I was suggesting that you split sunk costs among all the kW you consume.Okay don't really need a**hole replies like that. You should probably do a little more research into marginal costs and allocation. The point I was making is the $14 facilities charge is there whether I use 1 kWh or 1000 kWh so that is not relevant to the cost of adding the ~446 kWh of use I consume on an average month. If you want to allocate or amortize that over the whole amount so be it but in the discussion of what my fuel costs are versus my ICE vehicles it is definitely irrelevant.
I've run into that. I do my charging at home, so I say I love it, my car fills up while I'm sleeping/working/having lunch/playing with the dog. I absolutely love not spending any time sucking gas fumes filling up every week.But if they just go "bet you hate all that time spent charging", would just leave the conversation altogether. I am all for discussion and debate, love it, but the other person needs to come into it with at least the willingness to listen.
I think he did, that's why he dropped a cost that has nothing to do with charging his car out of the equation. It's a fixed cost that's not allocable to charging.You should read up on accounting & amortization.
This is exactly how I do it when folks sound interested. Very quick and easy using "current" prices or worst/best case prices. I like it better than eMPG which is energy equivalence, rather this is more like $MPG equivalence.EQUATION:
Gas Price * Mach-E miles per kWh / Electric Cost per kWh
Keep in mind the EPA estimated range of 270 miles for MachE ER AWD assumes basically 3 mi/kWh.
Example in Colorado NOW:
$2.79 * 2.7 / $0.125 = 60 MPG gasoline cost equivalent
Example in Colorado at worst gas prices in history and good EV range in June 2022:
$4.99 * 3.5 / $0.14 = 124 MPG gasoline cost equivalent
