Which cheap TPMS re-learn tool?
sukhoi_584th
United States
2022 MME CR1 AWD
I need to buy a tool so I can set the proper tire locations after doing a rotation on my 2022. Which of these will work?
https://www.amazon.com/VXDAS-Programming-Training-Transmitter-8C2Z-1A203/dp/B07WDFJKMB
https://www.amazon.com/VXDAS-Relearn-UL-50448-Pressure-Monitor/dp/B07YHPYHL6
https://www.amazon.com/VXDAS-Ultimate-EL-50448-Activation-Multiplex/dp/B07FP933LV
I'd expect the top link would work except there's a single foreign review saying it didn't work on the Mach-E. Is there a different re-learn tool I should be using?
snowy_91
James
Aurora, SD
2022 Mach-E Ice Blue GT Performance
The horn the car came with, push the emergency flashers button 3 times to get a horn honk. the dash will tell you witch tire to let air out of. release the air till you get a honk and move the the next indicated tire.
GreaseMonkey
Chicago, IL
24 Mach-E GT
I don’t think you need one. I bought the standard Ford relearn and ended up returning it cause 1) didn’t work and 2) didn’t need it.
Hammered
SE US
2022 PB F150, MME GTPE
Not necessary. Just drive and the car will relearn the positions.
This
You don't need a tool. If the sensors are on the right freq, the car will auto-learn the positions without issue.
We could swap wheels and both cars would know which sensor is where automatically.
sukhoi_584th
United States
2022 MME CR1 AWD
Ah, interesting. I had been going by this post which says the system must be re-trained when rotating tires. But I do now see @generaltso 's final post in that thread indicating the car does automatically learn the positions, which makes things nice and easy. As a side note this post (and @GreaseMonkey above) indicates the small gray tool with the green button does not work on the MME.
DanoiZ
SLC, UT
2022 Ford Mustang Mach-E GT
air out of
This
This is not my experience. I bought new winter wheel and tire set from TireRack with appropriate TPMS sensors, but they did not automatically learn. I tried the standard learning procedure (Hazard/Horn)...no luck. I picked up a Ford TPMS reset tool from $12 and that didn't work either. Called TireRack and they said to take it to one of their local dealers. I haven't taken the time to do that.
Sounds like they didn't install the right TPMS sensors.
DanoiZ
SLC, UT
That's what I said. I'll find out for sure when I take it to their tire partner.
Hammered
SE US
I got wheels off of another MME (aftermarket) and they worked immediately.
GreaseMonkey
Chicago, IL
24 Mach-E GT
Mine were purchased from tire rack too. It took a day of driving to reset.
GreaseMonkey
Chicago, IL
24 Mach-E GT
It takes time for the car to relearn. I switch between winter and all season with dedicated wheels / TPMS. When I install the all seasons that came with the car, the sensors get detected right away. When I put the winter set on with aftermarket sensors, it takes 30+ miles to relearn. But it happens by itself if you have sensors with the correct frequency. Just be patient.
Triggerhappy007
TX
23 Premium, 3rd Mach-E
Thanks. It was weird because it was reading correctly home from Discount Tire and 30 minutes into an hour drive yesterday. Parked it and drove an hour last night, still wasn't working. This morning after I posted, it's working again. I'll keep an eye on it.
