In my experience using sport modes on ICE cars, the vehicle revs much higher when aggressively pressing the accelerator. Thus, when you lift off, you are in a lower gear and experience transmission braking. I think this is what they are attempting to emulate.It makes sense that Whisper has the least regen for the smoother ride. However, I'd imagine that most would want the "sport" mode to not slow the car down more when they let go of the pedal. Am I the only one?
They are largely doing the same thing; whether they are attempting to emulate this or just attempting to improve range (for stop-and-go driving ... I believe higher regen braking on wide open highway more likely hurts range if you are not very careful with accelerator lift-off) is up for debate. FWIW, the Chevy Volt had the most intuitive regen mechanism of the 6 EVs I've owned to date ... Just moving gear selector from drive to low increased regen and made it much more responsive in stop-and-go traffic. I wish Tesla/Ford/ others adopted more intuitive and dynamic change of regen like my old Volts had.In my experience using sport modes on ICE cars, the vehicle revs much higher when aggressively pressing the accelerator. Thus, when you lift off, you are in a lower gear and experience transmission braking. I think this is what they are attempting to emulate.
For a REAR WHEEL DRIVE ICE car (or some RWD EVs like my RWD Mach E), in track or at least traction control disabled mode, you can press the brake and accelerator simultaneously to induce oversteer (front wheels grab and then rears will kick out more), which might make you go slower or faster depending upon the track, but is considered more fun by most. I use it to kick the tail out when I want to do donuts in the snow and it isn't quite slippery enough to do with throttle and steering alone. Apart from regenerating power, keeping the disk brakes cooler, and slightly quicker initial deceleration, AWD EVs don't gain any performance advantage from higher regen, and best Nurbergring track times on Model 3 Performance was obtained with lower regen to keep the batteries cooler and be able to do more than one lap without going into lower power mode.I actually believe it is for cornering... in an ICE car, if you want to take a corner very fast you can throttle with your right foot and brake with your left foot at the same time. It helps stabilize the car. Someone told me it was a technique used on the track, but I have never raced so I don't know it that is true or not. However in my last EV (Hyundai Ioniq Electric) it had these paddle shifters that allowed you to step up and down the amount of regen. When I wanted to take a long sweeping turn very fast (like an off ramp, or freeway connector) I could increase the regen (like downshifting) and accelerate through the turn and it worked amazingly. I actually wish all EVs had those paddle shifters for the regen, I think it was a great feature.
