- Jim
- Sep 10, 2020
- Wayne, PA
- 2021 Infinite Blue Premium Mustang Mach E ER AWD
- Retied (formerly tried to herd highly technical, independent cats)
Two things:
First, to reiterate: yes, Yes, YES I KNOW I can hit the “OK” button to dismiss the alert. That is NOT my issue. My issue is: why have the alert at all?
Second, to be VERY clear on my objection to the alert, I performed the following test.
consider: the warning is totally unneeded in the above scenario. The vehicle was at a complete stop, in park, when the seat belt was undone. The passenger door was opened and closed while the car was in park. Totally consistent with a passenger getting out of the car.
Clearly, no seat weight sensors are involved. There was no person or other weight on the rear seat anywhere.
So, again, why? The only even semi-coherent reason offered is regulatory.
- Came out to the vehicle. It was stopped and turned off.
- Opened the driver’s door to put a small parcel in on the passenger side floor. Did NOT close the driver’s door.
- Opened the driver’s rear door and fastened the rear driver’s side seat belt. Note that there was no passenger. Just a fastened seat belt.
- Closed the rear driver’s door.
- Got in the driver’s seat, closed the driver’s door, fastened my seatbelt and turned the car on.
- Drove off to my house
- About 10 minutes away from my house, I pulled into a parking lot, stopped, PUT THE TRANSMISSION DIAL IN P (Park).
- Turned and reached behind to open the driver’s side rear door (did NOT open the driver’s door or unlatch my seat belt).
- Unbuckled the driver’s side rear seat belt.
- Closed the rear passenger door
- Put the car in drive and drove home
