1 pedal driving
B25Nut
Charlee
Templeton, CA
www.bsi-inc.com
2021 Premium MME 4EX Star White, 2019 Acura RDX,
BSI Sales and Technical Manager
One of my concerns about one pedal driving is the logic Ford uses to determine when the brake lights come on. Has anyone run tests on this yet? One of my primary life philosophies is to consider and signal those behind you. One of my many pet peeves is seeing a driver that appears to always either have their foot on the accelerator or the brake - never coasting. I don't want to appear to be that type of person. I don't want to send a signal too early or too late to the person behind me that I'm slowing down.
woody
CO
Mustang Mach E, Chevy Bolt
I would find it hard to believe, as a gross oversight, that the brake lights would not come on. Would not be legal if they did not come on. Brake lights are a legal requirement. Both the Volt and the Bolt do.
But then again, I have no first hand driving experience with the MME (mine is somewhere out there).
Crilly
Dale
Hartland, Wi
Livewire prius prime Mach e. In 3 weeks if it was built yesterday
On one peddle driving does the mode setting make a difference in the amount of regen?
Have someone follow you and call them hands free with your cell phone. Ask them to let you know if/when the brake lights come on.
portlandg
grahame
Dorset UK
Black RWD ER and loving it
Cabinet maker
I had the same concerns when I took delivery of my current car, Kuga(Escspe) when using adaptive cruise control. I got my wife to follow in her car to test this out and yes, the brake lights came on. This car is 4 years old nearly so I would very surprised if our MME'S don't have the same set up.
Mantooth
Seattle
Test drove one in 1PD the other day in the dark where I could see the reflection in the signs behind me and the second I pulled my foot off the gas, the tail lights came on. Did not happen when 1PD was off.
OttawaGuy
Gatineau, Canada
Mach E RWD SR, F150 XLT Special Edition
Busy!
I would hope that there is some sort of logic to the brake lights coming on.
If the car is really slowing down noticeably fine, but if you are just lifting the pressure slightly I hope they don't come on instantly... Nothing more annoying then follow a car that has red blinking xmas lights on
But it all depends on the amount of slowing down force is applied when you pay with the pedal
B25Nut
B25Nut
Charlee
Templeton, CA
www.bsi-inc.com
The brake pedal uses regeneration for most braking situations, so I do not feel 1PD will prove to be significantly more efficient. I can also see a split second difference in the time to make the decision to use the brake pedal in an emergency.
Mwjdavies
Martin
Uk
Mach E RWD SR Rapid Red
I believe so yes (Hopefully others will confirm). So the Unbridled / Untamed mode has the highest form of regen, whilst Whisper has the least so I believe.
Holy Driver
Lars
Germany
Mustang Mach-E RWD SR
What happens when you release the foot immediately from the pedal?
WIll the car stop immediately?
lotharik
Maryland, USA
Mach E, duh?
It comes to a gentle stop. If you're coming up to a stop sign in a residential area, there's a certain distance where you can let off the pedal and not need the brakes at all.
One pedal driving is really smooth and I highly recommend it.
JamieGeek
Southeastern Michigan
spareelectrons.wordpress.com
Yes--just like you hit the brakes.
In addition, if you're on snow the ABS will kick in (yes first hand experience with this).
benk016
Ben
Tulsa, Oklahoma
2021 Mustang Mach-E GT
If you ease off the pedal, it will start to slow down, as if you're gently applying brakes. If you fully let off, it slows you down much faster. Like you're applying medium braking. Then if you need more, you can use the brake pedal. But When you let off the accelerator completely, it will come to a complete stop and hold you there until you push the pedal again.
Londonboy49
Maine et Loire France
Mach-E Premium Extended Range AWD
The brake lights come on when foot is lifted completely. You still need to brake if you want an immediate stop.
