12 volt battery replacement prices?
David bernd
davdi
naples fl
2023 Ford Mach e GT
what kind of prices are you seeing to replace the 12 volt battery? Dave
The battery lists for about $135. It takes about 30 minutes to install and reset the BMS.
People on here have reported dealer prices all-in between $200 and $1000. I guess it depends on how sleazy your dealer is.
Guss-E 2021
Pierre
New Hampshire
2022 Mach-E Prem AWD ER
Compliance Specialist
I just stopped into a local dealership and asked. Was quoted $330 ($270 for the battery). There are a couple Ford dealers in my area so I'm going to check with them all.
SOSMachE
Stephen
South Florida
2022 Mach E premium AWD ER - Iced Blue Silver Metallic
Just had my 12V replaced, as soon as my car hit 3 years of ownership. The dealer charged $130 for the battery and $60 labor. Quite reasonable in South Florida. Also had the brake fluid replaced for $150. Total out of pocket maintenance costs during the 3 years is less than $250 (since I had some Fordpass points gifted by Ford that came in handy).
Mark Hassa
New Westminster, BC
2024 Grabber Blue GT
Government Food Inspector
If your car/battery is under 3 years old the battery is covered by warranty.
SOSMachE
Stephen
South Florida
True. I waited till the three years were up. With all the horror stories of the 12V locking people out, I did not want to wait till the battery failed.
Space_Pony
Indiana
2023 Premium Mach-E awdX
Wouldn't you have to demonstrate symptoms that the 12v battery is defective or do you just go to the dealer when the car is 2 years and 11 months old an tell them you want a new battery?
smoke20
Gone
Gone
I recently decided to have my battery replaced by the dealer at my expense. My GTPE is a 2023 (11/22 build). Service adviser asked why I wanted a new battery….”just because…..please replace it.”
SA called and reported the battery tested bad and they would replace it under warranty. I had no idea (no known symptom) my battery was ‘bad’, but I’m thankful I went in while under warranty.
Mark Hassa
New Westminster, BC
In my case, I was in at 2 years and 11 months getting a last check done and addressing some module updates. I read about lots of people having their battery die around the 3 year mark, so I asked them to check my battery. They have a way to test it, and told me it was failing. I had no symptoms, but they told me it was covered by its own 3 year warranty.
They replaced it along with doing a BMS reset.
Tbird
Denny
New Hampshire
I purchased the BAGMH3 from Fordparts online for $ 119. It was sent to my dealer and they installed it. $225 labor charges. Took them abt 45 minutes shop time. I was getting close to 4 years on the 12v battery and just did not want to get caught in the cold with a dead battery
SteveMach-ee
Mass
2021 MME Select AWD, 2023 Ariya Venture+
Also purchased the BAGMH3 from Fordparts online in December but for $132 plus $18 for the core charge that I was refunded. Picked up at local dealer. Installation was pretty easy following the forum instructions.
Tbird
Denny
New Hampshire
I should have installed it myself but did not have time. Had a trip coming up.
Tom L
Tom
Chippewa Falls, WI
2018 Honda Clarity
I had my 2022 CR1 with 56,000 miles in for service this week to replace a faulty door sensor, so based on this posting I had my dealer check the 12V battery. It tested out at about 300 amps, so that was low enough to justify replacement. They charged me $138.
This has been my only service cost in 3 years. That is my best and least costly experience in 60 years of owning cars.
Space_Pony
Indiana
So warranty covered the door sensor but not the battery?
Tom L
Tom
Chippewa Falls, WI
2018 Honda Clarity
The battery replacement was $138. The door lock sensor problem occurred after the warranty expired, so the cost for that was $568. It was a harmless error that always cleared by the OK button but came up each time the car was started. We plan to get a new EV soon so I didn’t want the next owner of the Mach E to be saddled with a confusing error (or a failing 12V battery).
