12 VOLTS BATTERY DIED WITHOUT WARNING!!
4wheeldog
7200' elevation New Messico
2024 Premium AWD Extended range
Retired a long time
Well, I read that Darren thing on LinkedIn just now I’m sorry but I didn’t see anything that said he said the 12 V battery lasted a lifetime. Maybe I just didn’t read it right I don’t know.
In my experience, all 12vdc lead acid batteries (AGM or “conventional”) have a lifespan. So if you squint and hold your tongue just right, they are “Lifetime”.
4wheeldog
Retired a long time
In the first rendition of Ford-Pass, we had a LVB right below the picture of the car. I didn't like when they removed it and would definitely like to see it come back. But it only showed whole volts, not tenths like you would need for accurate monitoring.
Raw voltage is not an accurate measure of the health of a battery. I have seen batteries at full rated voltage in absolute failure when load is applied.
alexgorod
Alex
DBA
I have 49 months on my LVB and it is still going strong. I check it regularly to avoid an unexpected failure. I am expecting failure sometime soon but no signs of that yet.
Can you share how exactly you check it?
I didn't see any issues with mine, but replaced it around 34 months.
Scarpia
US
You kind of come across as scolding this guy for not doing something that nobody should have to do.
I didn't infer scolding, and what anyone "should have to do" is subjective (aka "in a perfect world").
It's not a perfect world, and the reality is that this battery failure happens and is well-documented, so you "do have to do it"...or you will be stranded at some point. We all wish Ford had given better alerts for this, and made the battery easier to access, but they didn't.
4wheeldog
Retired a long time
I use a cheap tester from Amazon equivalent to this: https://a.co/d/foYvK92
Even better would be an actual load tester, but since I have never had an unpredicted failure since using these, I believe the cheap solution is sufficient. Plus a load tester arguably can accelerate the failure of a weak battery.
Sikkun
2023 Mach E
prone to hyperbole aren't we?
I believe they are one of, the very rare, people that managed to have the 12v die after shutting their front door, the doors being locked, so they now couldn’t open them.
And the kids being too young to operate the inside manual locks.
Now why the super capacitors that are also supposed to be in the doors allowing them to unlock a couple times with no electricity also failed???
Jerrytball
Jerry
Gulfport MS
2026 bmw i4 M50
I’ve only experienced the tongue in the squint on a 9 V battery sorry?
SCP31
North Country NY
2025 Mustang Mach e Premium, 2015 Audi TT, 1968 Triumph
My MMe GT is a 2021 model and is within a few days of turning three years old. It just clicked 50,600 miles. I have the 12 volt battery tested every time I take it in for service and, so far, it has tested fine. The time it tests marginal I will have it replaced. I'm thinking that perhaps I should replace it with a battery like the one in my Audi TT. My TT is a 2015 model (purchased in August of 2014) with 77,800 miles on it and still using the original battery. Yep, it's over ten years old and still going strong. I have it tested at each service and the service people say it's fine and doesn't need to be replaced. Go figure.
Jerrytball
Jerry
Gulfport MS
2026 bmw i4 M50
My wife flinches when I check 9 volt batteries that way. But it is a quick and accurate method.
It’s unreal how much that little 9 V battery can power it keeps this windshield on the Mustang powered up for 15 hours. But I switched it off when not in use so that thing will last forever cause I only turn it on at night and I don’t drive much at night.
Ford Mustang Mach-E 12 VOLTS BATTERY DIED WITHOUT WARNING!! IMG_9839
Snakebitten
Coastal Texas
2023.5 Mach-E
That Audi battery may in fact be a higher quality battery than the one in the Mach-E. But I don't think that has much influence on the disparity between the lifespan of both batteries.
Bet the Audi battery is bigger than the H3 in the Mach-E. So with the additional headroom/capacity, it's less likely to have its voltage dropping into the unhealthy zone. Certainly not as often.
But the biggest difference is that when you turn that Audi off and go in for the night, the car actually leaves the battery alone. Let's it rest. Unmolested until the next time you wake the car up.
The Mach-E?
It tortures that poor little H3 incessantly! Wears the little fella out.
tucsondivots
Walter
Tucson, Arizona
2024 Mustang Mach E Premium
A somewhat Related question: Does leaving a usb thumb drive plugged in (music) drain the 12 volt battery if you leave it in after the car is off?
