BillPitman
Pa.
Ford Escape, ā€˜21 J2 Mach e, 2024 Maverick Hybrid
Lmoto
andy
florida
www.lithiummoto.com
mach e
mechanic
Does anyone know where to find the data on the 12V battery ?
It seems to be a H3 size, but, i can not find it anywhere.. anyone know the dimensions ?
thanks
thanks
I encourage you to use the Forum's search feature. It has been published here.
Shayne
Northern Ontario Canada
2021 MME4x Prem
thanks
Original 12V: FoMoCo BHAGM-H3 (35 amp/hr)
BCI/ DIN H3
MotorcraftĀ® Part Number BHAGM-H3
Cold Cranking AMPS (At 0° F) 380
Reserve Capacity (Minutes) 60
Maximum Dimensions Inches (mm)
Length Width Height 6.9 (175) 6.9 (175) 7.5 (190)
Approx. Weight (Wet) LBS. (KG) 27 (12.1)
fpasta
that is how I used it at the drive-in, just on in P.....
I want to know more about this. I want to watch a movie at the drive-in theater near me to test the surround sound system. I know I'm going to have to toggle that switch that auto powers the car off in 30 minutes, right? What is the right thing to do? If I just leave the full accessory power on that's draining the 12 volt battery which I don't want to happen. I don't want to be left stranded. So I'm thinking the latter.
Marcel
The Netherlands
Woodworker
Just leave the car on...do not switch off?
Yes leave car on, battery will die in accessory mode like a regular car if left on too long. Warning will pop up on display after 30 mins and you can just hit OK to stay on, or find it and disable in the menu.
cbcasas
Christopher
2024 Premium
So 12v while not using the car is ā€œnormalā€? I only ask because most of the time I’m at 13v-14v while not using the car and recently it’s been sitting at 12v (via Widget).
