- Lee
- Jul 16, 2021
- Wisconsin
- 2022 Mach-E Premium AWD
- Sci/Eng
OBDLink MX+ and Vgate iCar Pro 4.0 BLE are the two adapters I've tested and verified to have a low enough standby draw (<5mA) not to drain the 12V battery. Other adapters can have higher standby drains and drain the 12V battery, so it's best to leave them unplugged (it's also a security risk with most adapters since anyone can connect to your car). Leaving the Car Scanner app active in the background (forgetting to disconnect and quit the app) can also cause a major drain since the car won't go to sleep while data collection is active.@Mach-Lee thank you for this most excellent write-up. I cannot believe I am only seeing it now, but I appreciate the time and effort you took to put write down all of this information. If I may pick everyone's collective brain... is there any issue leaving the OBDII reader plugged in or should I remove it? Second, using a Carista OBDII and a Car Scanner app, my SOC for the LVB is 71% when I turned it on today and the wifey had not driven it since Sunday or Monday. I bought the MME in July of 2021 and it has about 22k miles on it. It has been garage-kept for all of its life although it had been in the sun periodically whether at work or driving around. When do I know it is time to change the battery? A most recent update did not complete although I don't know the reason. With my other vehicles, it wasn't as big a deal if the battery were to fail because it was easy enough to open the doors and hood to jump the battery. Lastly, when is the best time to check the battery's state of health? I also have a little voltmeter in the cigarette lighter power outlet in the armrest and it shuts off automatically, but it has been reading between 12 - 14 every time I check. TIA.
A 12V SoC of 71% is perfectly normal after the car has been sitting. I would not worry about this. If you have trouble with an update installing, see my other topic about getting failed OTAs to install.
You cannot check the 12V battery's state of health. You can check the state of charge, best time is to use Car Scanner is right after you start the car. The battery will drain 10-15% after you shut off the car, this is normal. Again, I would not worry unless you consistently saw SoC values below 60%.
Yes the lithium jump start packs are acceptable to use. Keep in mind the amperage ratings they put on them mean almost nothing because there is no standardization and the manufacturers can claim whatever they want. The medium size ones or larger should work okay. Looking at Amazon, it appears that would mean something like >2000A peak amps and capable of starting a 6.0L diesel.I saw the answer on jump starting but I'm not familiar with the different technologies. Are these Lithium-Ion devices adequate?
https://a.co/d/4sFuF3a
If so, what's the minimum amperage/Wh?
However the most important thing the lithium jump pack needs to have is a manual override or boost button, otherwise it will be useless for opening the frunk. I see not all brands have this anymore. The override allows the jump pack to supply power even when no voltage is detected on the terminals (which is the case with the frunk leads). The override is usually a small button somewhere on the safety device at the base of the jumper cables. FYI it appears the one you linked does NOT have an override, so I would not buy that one. My preferred brands are NOCO or GOOLOO which do have the boost/override capability.
