2021 standard range battery capacity
flapjake314
NYC
Mach-E Select AWD
Can someone remind me of the kwh usable capacity of the 2021 standard range. my window sticker said 68, did one of those updates change it to 70 or something like that?
Howard
Howard
West TN
'23 Premium RWD ER CG Mach E & '25 Blazer RS EV
There was an OTA last year that changed standard range usable capacity from 68 to 70 kwh. I don't remember which one it was though.
PA Bob
Robert
PA
Premium RWD SB
Just keep in mind that you want to keep the battery between 20% and 90%. Some people keep it between 30% of 80%. If you keep it between 20% and 90%, you lose 30% of your capacity. That’s about 23 kWh. That makes your practical capacity about 47 kWh rather than 70.
bdonpwn
Roseville, CA
2021 Mach-E SR w/ Tech Pkg, 2006 Evo IX
“The 2021 Mach-E was originally released with a standard 68 kWh battery (75.7 kWh gross) and an optional 88 kWh extended pack (98.7 kWh gross). For the 2022 model year, the usable capacity of these batteries were bumped up to 70 and 91 kWh while the gross size remained the same.”
Ford doesn’t intend on adding those 2 extra kwh to the 2021 as I believe it’s an added value thing specific to the 2022.
Added. Discussed many, many, many times.
Ford Mustang Mach-E 2021 standard range battery capacity {filename}
Except that they already did. But let’s not go back to the countless pages of threads where this has already been discussed ad nauseam.
