2026 Velocity Blue GT/CS
2024 AWD 91 kWh ER battery VS 2025 AWD 88 kWh ER battery
Same estimated range.
Why does the 2025 with a smaller useable battery capacity take longer to charge?
Can confirm the non-GT extended range battery has shrunk slightly for 2025. They reduced the size of four cell modules, making the new 88 kWh pack 4P90S. The GTs will continue to have the existing 91 kWh 4P94S pack.
I guess they figured since they made the car more efficient they could reduce the battery size and still have 300 miles of range.
Ford Mustang Mach-E 2025 Mach-E Order Guide New 88 kWh battery
Pioneer74
Pioneer74
Dearborn
2022 Lightning Lariat ER - 2025 Mach-E Premium ER
Ford Mustang Mach-E 2025 Mach-E Order Guide {filename}
It's a cost savings. Just like the 2025 Job2 Lightning Flash having a smaller extended range battery than the Lariat and Platinum.
Shrinkflation has officially moved from candy bars to cars!
Ford Mustang Mach-E 2025 Mach-E Order Guide IMG_1970
vredMe
Baleed V
BHM, Alabama
Volvo XC60 and Future 2025 Mustang Mach-e Premium eAWD
I placed order for Premium with extended battery and 20" wheels...LA Car shoe video on MME 2025 mentioned that Ford is offering complimentary home charging setup / standard installation, but this is not mentioned in 2025 MME order form ???
Just got email from FORD with VIN # and production scheduled for March 10, 2025...crossing fingers !!!
DevSecNetAIOps, General PITA
So here's something I stumbled on:
Ford Mustang Mach-E 2025 Mach-E Order Guide Screenshot 2025-02-03 at 1.41.58 PM
Magna2? I can't find it anywhere in the order guide but that would really be something if it's true. The above is the shocks listed for the rear of the 2025 on parts.ford.com
spartan
SE Michigan
2013 Focus ST; 1996 Camaro Z28
Hmm, maybe that's the MR hardware for the Rally?
But tied to the Sport package on the premium.
Even crazier is the near $400 rear spring (that's normally around $75 maybe $100)
Ford Mustang Mach-E 2025 Mach-E Order Guide Screenshot 2025-02-03 at 1.53.21 PM
phil
LS400
DuskE
James
2019 Mustang Bullitt, 2008 Mustang Bullitt
@azerik MagneRide Damping System 2 is the version used on Mustang Mach-E Rally, not the suspension system used on the Premium Sport Appearance Package. Be sure to enter a VIN should you decide to order parts off that site to help ensure you are choosing the correct ones (although i assume you were just perusing :wink:)
