sgriffin130
Thompson Station, TN
'22 Red Mach E- C/T Pkg, '23 Escape PHEV/Prem Pkg
Dentist(retired)
Grab a magnetic tool, extend it into the opening where you are missing the clips and slowly navigate toward the trunk (gravity) and you will successfully recover the clip!
Thanks I'll try it if I can get my tool into the opening.
cl0udmaster
Mustang Mach-E 4X (Infinite Blue), Lotus Elan
Hi @EV_Vida any updates on v2 of the pony that is glows white until the brake is pressed?
EV_Vida
Simon
Mach E CR1
My updates would be looking more like January. With the holidays and Covid in the east where some of the components are assembled, delays appears inevitable. Plus we need to QA/QC the sh*t out of it to make sure it functions as it needs to.
RedOctobrrr
'23 Mach E Select AWD
Is a white light in the rear that ISN'T for reversing legal? Technically, could you get pulled over for a white "reverse light" while driving on the highway?
(It's obviously not in reverse, but looking at it through the lens of a cop eager to write a ticket)
Sundevil
AZ
Mach E
From what I remember when the V2 was posted briefly on the website it's only white when you approach the car. Once it's moving it's always red and the red intensifies when the brakes are pressed
abr
thousand oaks, ca
2021 MME FE RR, 2019 Fusion PHEV
That's the way it should be . . . can't be white while driving.
If you can do it that way, terrific!
Lb8403
Washington
2022 MME Premium EXT AWD
@EV_Vida can you clarify/verify this?
MrMajor
Brandon
United States
Mach E Premium
We don’t want to disappoint anyone but the approach light (white LED) is a feature that we hope to announce on the higher price point rear pony brake light.
I know you guys are working hard, I'm just curious if there's any update on V2? I was about to place an order for V1 but should I hold off? If V2 is expected anytime soon, I'd much rather pay the higher price for that version.
AliRafiee
Ali
Seattle WA
2022 Mach E GT - Grabber Blue
Software Eng.
Just installed mine today. Very good product. I just wish it was always on and got brighter when I step on the brake.
the shape and finish matches the front one on my GT perfectly. (I took the sticker off, was not very high quality)
Old_Norm
Columbus Ohio
Any issues or tips for getting the panels off?
AliRafiee
Ali
Seattle WA
Software Eng.
I heated it up with a heat gun for a couple of minutes. Then used an emblem remover line.
Carefully put a trim removal tool under it to get it away from the body on each side and it pealed right off. The tabs aren’t holding it very tight.
Mine is a GT. The emblem got bent when I was pealing it off.
I also heated the adhesive that’s under the emblem and that pealed off too.
