precisionair
Woody
Grandview Tx
2023 Lightning ER Pro & 2025 MME Rally
HVAC Contractor
Should deflect small road debris, screen behind will stop bugs/leaves from entering radiator/condenser area. About 50 bucks in materials including screen (lowes gutter screen) & push pins to secure it. Photos show cardboard template, cut ABS grid, and screen (attached with small UV resistant zip ties). Push pins from Harbor Freight.
Ford Mustang Mach-E Active Shutter shield DIY for Mach-E Rally - GT IMG_7881
Ford Mustang Mach-E Active Shutter shield DIY for Mach-E Rally - GT IMG_7882
Ford Mustang Mach-E Active Shutter shield DIY for Mach-E Rally - GT IMG_7883
Ford Mustang Mach-E Active Shutter shield DIY for Mach-E Rally - GT IMG_7884
Ford Mustang Mach-E Active Shutter shield DIY for Mach-E Rally - GT IMG_7880
Ford Mustang Mach-E Active Shutter shield DIY for Mach-E Rally - GT IMG_7879
Ford Mustang Mach-E Active Shutter shield DIY for Mach-E Rally - GT IMG_7878
Ford Mustang Mach-E Active Shutter shield DIY for Mach-E Rally - GT IMG_7885
E90alex
Seattle, WA
‘25 MME GT
It doesn’t cause issues with the parking sensors, radar sensor, or the grille shutters opening?
precisionair
precisionair
Woody
Grandview Tx
HVAC Contractor
So far no… I guess being non metallic and made of the same material as the sensor n
precisionair
precisionair
Woody
Grandview Tx
HVAC Contractor
Oh, and no on the interference to shutter opening and closing, as it gapped about 1/4” from shutter assembly
precisionair
precisionair
Woody
Grandview Tx
HVAC Contractor
Also, if you’ll note… I didn’t cover the two sensors with the metal screen for that purpose
JohnFoxeSheets
San Francisco
johnfoxesheets.com
precisionair
precisionair
Woody
Grandview Tx
HVAC Contractor
Much obliged🤗
The cruise control radar in the center will not be happy with the mesh screen, that might cause problems.
ipca204
even if non-metallic?
precisionair
precisionair
Woody
Grandview Tx
HVAC Contractor
That’s awesome… to bad kits aren’t available for our MME’s
XPLOR
Robert
New Mexico
2025 MME RALLY; 2024 MME Premium
There is no screen over the center section. I inadvertently used mock-up photos, and not the final pics. The included pic shows no screen.. (zoom in)
It looks awesome! Could you post where you purchased the materials?
Again, love the look and protection! Thanks!
precisionair
precisionair
Woody
Grandview Tx
HVAC Contractor
Other than some tin snips, drill an bit, here’s the material items I used: The ABS grid from Amazon, the black wire mesh from Lowe’s (gutter guard), the push pin variety pack from Harbor Freight, and the small zip ties also from Lowes
Ford Mustang Mach-E Active Shutter shield DIY for Mach-E Rally - GT IMG_7914
Ford Mustang Mach-E Active Shutter shield DIY for Mach-E Rally - GT IMG_7915
Ford Mustang Mach-E Active Shutter shield DIY for Mach-E Rally - GT IMG_7916
Ford Mustang Mach-E Active Shutter shield DIY for Mach-E Rally - GT IMG_7917
precisionair
precisionair
Woody
Grandview Tx
HVAC Contractor
And for the template, I used a piece of the cardboard from the sleeve type box the grid came in. Good luck!🤗
