Advice: Preconditioning
nvarras7
Nick
Rhode Island
2023 Premium Mache-E, 2022 NW Tiguan SEL
Dental Lab
I have my Departure time #1 Set at the time I leave my house in the am. I use the Second tome to change when my departure times change. Takes about 1 min. It's not the big of a deal.
Unclespike102
Green Bay
Mach E Premium
I have a thought - and I’m not being cynical - I’m simply fed up with Ford’s inability to provide a current interface on EVERY aspect. It’s 2024 - not 2004!
Not sorry if this offends anyone - this simply a realistic observation and comment.
Ford needs to provide a ā€˜Precondition Now’ button. Click and done!!! This isn’t a revelation - it’s just common sense.
ā€˜Only takes a minute’ is not acceptable - what App do you use that it ā€˜only takes a minute’ do you use! Answer: NONE!
and if you are spontaneously leaving, you don’t have only a minute.
has anyone with an objective view at Ford ever use their products? This is your Flagship EV - put resources into improvements!!!!!
SMH
kkgg
Minnesota
mach e
Yes, ford should work on implementing on demand pre-condition button in the app/car.
It clearly make the car lot more efficient.
Not everyone lives a robotic life where they can forecast departure time for the whole week.
MoonRiver
Tampa Bay, FL
Ignoring the long trips with a need to drive pretty far to reach next charging point, but for regular daily trips of 50-100 miles, what is the point of preconditioning?
I have been wondering the same thing too. My understating is the battery produces more juice and takes charge easier at a warmer temperature, but as long as I have enough range to begin with and wouldn't need charge on the road is it necessary to precondition the battery?
You're in Florida, so I doubt it gets cold enough for you to need preconditioning.
Much different story up here where you need preconditioning to have decent acceleration, range, and heat.
kkgg
Minnesota
mach e
Hm. Not everyone can plan the range they need upahead. Life happens ✌
Teslaeata
Nottingham, England, UK
This morning as I was unlocking car by ā€˜phone and saw a ā€œStartā€ button here where shown in attached but now it’s disappeared.
It may well have been present whilst car was plugged in to charge point.
Is this the pre-condition on demand everybody’s been mithering on about?
Ford Mustang Mach-E Advice: Preconditioning IMG_7780
d_k_g
2014 Mach-E premium AWD extended battery
All that start button does is ā€œstartā€ charging again once the target charge has been reached. You will only see it when it’s plugged in and not charging.
Herbknowsit
Herb
2024 Mach E Select AWD Ext battery-Comfort Package. Eruption Green
Retired after too many years traipsing the globe for a paycheck
Wow! 300 miles at 94%. I’ve got extended range and even in summer don’t see that range. . And I drive pretty conservatively.Almost always Whisper
Ford uses a different algorithm over there because the range rating is vastly different than our EPA rating.
And drive mode is irrelevant.
Herbknowsit
Herb
That’s comforting….I was ready to ask Ford for a buy back. Just kidding!!!
Teslaeata
Very many thnx, makes perfect sense now, rarely charge under 100% and when I do don’t usually pay much attention to the FP screen when I disconnect in the morning after a charge hence I never noticed it before?
Every day’s a school day ?
Teslaeata
300 miles at 94%, where’s the big red button……..
Teslaeata
Once I’m on the road the realism hits home and the true range soon becomes 240 winter and 270 if I’m lucky in summer.
TBF to car & Ford I’m usually fully loaded to maximum permissible weight and at highway speeds a lot of the time with heat & A/con running so not exactly the most economic way to use an EV.
Still bloody impressive at over 110,000 miles and HVB at 93%SoH.
You just gotta love these cars ?????
HughJazzol
Norman
Miami
2024 MachE Premium RWD
Project Manager & Swim coach
Hey Lee
I've read all the pages of this post, and I have a slight headache.
In Miami, I bring the car into the garage daily to protect from the sun, pollen, etc. On average, I leave at 3pm to pick up my daughter. I drive 22 miles round trip.
Do I need/should I plan a departure time in the app to precondition?
I assume, no.
