All connected services are gone
Dysan911
2023 Mustang Mach E GT
Technical Software Analyst
I noticed at home this morning my Xfinity App told me that a new SYNC joined the network with Strong Wifi. Ever since then all of my connected features have been non-functional. I've never encountered anything like this before and wondering if this is another scheduled Dealer visit situation or something I can try myself.
So far..
  • FordPass app shows old information on Charge % and Range (Says Updated 11 hours ago)
  • FordPass remote Start, Lock, unlock, etc non-functional.
  • Inside the vehicle the Connected Services menu is empty
  • No Icon at the top of the screen that typically indicates a connected vehicle
  • Nav shows No Weather or Traffic Data.
  • blank when you refresh. Won't even connect to Wifi. Avail networks are blank on refresh.
I have restarted the Sync a few times and no luck. Is there a fuse I can pull? If so which ones and where?
Ford Mustang Mach-E All connected services are gone IMG_8032
Ford Mustang Mach-E All connected services are gone IMG_8033
Ford Mustang Mach-E All connected services are gone IMG_8034
Jlbern27
Socal
Mach e
My plug and charge didnt work this morning. I had to start the station from the ea app
Dysan911
Dysan911
Alrighty!. Well I guess it's back to the Dealership. I found a post that said fuses 11 and 12 can be pulled and wait about 10mins. I took those out for about 30mins and put them back a moment ago and still nothing. You can see the WIFI symbol show up briefly and then it goes away. I was able to view avail Wifi Networks for a few secs and then they were all gone. So def some sort of internal modem is having issues. :(.
RogueLegend
Shadi
Seattle, WA
Mustang Mach E Premium AWD
I had this happen to me last Friday. Saturday, I called Ford support. They had me conduct a few restarts, including one that involved holding the steering wheel column buttons down for a full minute. We did everything except pull fuses. None of the steps worked.
On Monday, the issue remedied itself, including remote start. I almost took it to the dealership too.
I have a 23 Premium AWD Extended battery.
Dysan911
Dysan911
I tried one last-ditch effort thing. At the bottom of the fuse panel there appears to be a black power connector. I unplugged it and you could hear some stuff power off and restart when I plugged it back in. It worked!. I first noticed the WIFI symbol was back and then within a few mins the little Connected Services icon. All items under Connected services were back and now the app is updated and everything working.
Im not sure what Fuse should have done the same thing but I pulled a 3 prong fuse that's marked 11 & 12. It did NOTHING. A lot of people mentioned in threads I found to pull the negative cable from the battery and let the vehicle sit. I guess whatever I pulled had a similar effect.
AlpaChino
JB
Indiana
2025 Kia EV9 Land
Which fuse box, and what black power connector? I've disconnected the negative terminal on my 12 volt battery for up to 4 hours previously and have not been able to perform a 12 volt reset to get my connected services going again. This would be tremendously helpful, thank you.
Dysan911
Dysan911
I think technically Fuse 21-22 are part of the Gateway Module and might be one to try first but if that doesn't work then Here is the Power cable I pulled for a sec which restarted a lot of components that got me up and running..
Below: When you remove the access panel in the Passenger Foot Well.
Ford Mustang Mach-E All connected services are gone IMG_8038
The Lower wire bundle that has the tan piece of tape and you can see one of the big Red wires on the far right. There is a release tab on the bottom of this connector. Just pull it and everything will shutdown. Plug it back in and give it a few mins for all the modules to boot up, etc. HOpe this works for you!
Ford Mustang Mach-E All connected services are gone IMG_8039
dyandell
2023 Ford Mach E GT
I just bought a Mach E about three weeks ago and I have been having this problem. The only differences is Connected Services works intermittently. I do not have my home charging set up yet (hopefully today) so I have been going to a fast charger once or twice a week when my SoC gets too low to get the battery back up on its charge level with the wall charger. It seems like Connected Services stops working when I plug it in. I have noticed a couple of times it works prior to getting to the charger and then when I plug in, go to watch YouTube, Connected Services stops working. Anywhere from a couple of hours to a couple of days later it will start working again.
rugedraw
Javier
Miami, FL
Auto Sales
AlpaChino
JB
Indiana
2025 Kia EV9 Land
Hey there,
Just wanted to share that your advice here helped me fix this today. You did what Ford support could not. Thank you!
Dysan911
Dysan911
Hey there,
Oh man that is awesome! Glad that trick resolved yours as well. I was just waiting for someone to post that unplugging that connector would cause the car to catch fire or spontaneously explode or something lol. :p
By chance did your auto wipers kick on when you unplugged yours? I think I had mine in the Auto Rain Sense position and when I unplugged that connector it probably powered off that module among a bunch of others.
AlpaChino
JB
Indiana
2025 Kia EV9 Land
Here's the steps I took.
  • Turned the car off.
  • Opened up the passenger footwell fuse box.
  • Disconnected the small harness you described, as well as all others. I left the fuses in.
  • I opened up the frunk and disconnected the 12v negative cable from terminal.
  • I waited ten minutes.
  • Reconnect all connections in fuse box
  • Reconnect 12v
  • Start car.
  • Turn off and turn back on connectivity menu options.
  • Open up FordPass and verify connectivity.
I did not have to reset FordPass, PaaK, uninstall/reinstall the app, or remove/add the car to FordPass.
No strange behaviors when restarting the car, thankfully.
fatboy8
Matthew
Washington
2023 Mach E Premium AWD Extended battery
Just wanted to add that I've been pulling fuses and disconnecting batteries for the last 2 days trying to get my connected services to work again and trying to get Fordpass connected after doing a master reset. Pulling the power cables to the fuse box did it. Hopefully it holds for a while. Every now and then pulling one of the fuses would get things working again but it would lose connection after a short while.
Thanks for the tip of pulling the power block. That's way easier than trying to remove and replace those tiny fuses with my fat fingers.
Ps2roy
Roy
Georgia
2023 Mach-e GTPE (vapor blue metallic nite pony)
Tried pulling fuses without luck. Pulling the power block did the trick. Thanks
cooltatts
Mississauga, ON
2024 Mustang Mach - E Premium
Thank you, have had the car two weeks and after coming back from a short drive the car lost all connectivity. Unfortunately, I reset the app, reset the screen, etc before finding your post. Nothing worked. Then I followed your directions and removed that one power line in the passenger footwell fuse panel. Waited ten seconds and reconnected. Now everything works again. Thanks for the tip on the release tab too. Such an easy fix. Now I know what to do first next time.
