Ambient lighting setting missing
SERSusie
Susie
Chatham NJ
2021 Select SR RWD
I have a new 2021 Select SR RWD. I’ve had it since mid-November I believe it has ambient lighting but there is no setting for it.
Nothing below “voice control” when I scroll down.
anyone else had similar issues?
Thank you
Santiaventura
Santi
Valladolid - Spain
Mach e RWD SR TECNOLOGY+ & WHITE STAR
Tengo un nuevo 2021 Premium SR RWD. Lo he tenido desde mediados de noviembre, creo que tiene iluminación ambiental, pero no hay configuración para ello.
Nada por debajo del "control por voz" cuando me desplazo hacia abajo.
¿alguien más tuvo problemas similares?
Gracias
[/CITA]
mi RWD SR tiene dos semanas y no tiene luz ambiental (coche europeo), si son igual en USA no busques más, no lo tenemos...
Orion One
Belgium
MME ER RWD
Surgeon
Hi, I have a ER RWD and no ambient light. I heard only the AWD models have it.
Same for the signature headlamps... still a wonderful car ?!
I have a new 2021 Premium SR RWD. I’ve had it since mid-November I believe it has ambient lighting but there is no setting for it.
Thank you
I remember reading about another owner with the same problem. It turned out that the "as built" configuration in their car was incorrect and had to be corrected by the dealer.
That's the case in Europe, but not in the US.
SERSusie
Susie
Chatham NJ
2021 Select SR RWD
Thank you. I've seen others complaining about it too. There appears to be a hole but no bulb under the armrest! I'll contact the dealer.
Santiaventura
Santi
Valladolid - Spain
Gracias. He visto a otros quejándose de ello también. ¡Parece que hay un agujero pero no hay bombilla debajo del reposabrazos! Me pondré en contacto con el distribuidor.
[/CITA]
si averiguas algo de esto házmelo saber por favor, estoy en el mismo caso. En mi concesionario lo han solucionado con un "lo sentimos pero es lo que hay"...
Gracias
benk016
Ben
Tulsa, Oklahoma
2021 Mustang Mach-E GT
