Apple Maps
  • Thread starter Deleted member 19354
  • Start date
  • Watchers 4
Guest
I like Apple Maps as a guide etc. I have iPhone 15 ProMax.
I’m not a fan of EVGo and that’s all the charging options it gives. I can’t figure out the settings. Prefer EA myself
Thanks
DRCal68
Gold River, CA
2023 MME Premium 4X Ext, 2018 Tesla Model 3
When you open Apple Maps on your phone, click your photo, select vehicles, then click your car.
From this screen you can edit and add networks.
I am new to the MME, and carplay. I do not see any option under my picture in Apple Maps for ‘Vehicle’.
Thanks for any help!
Guest
Tap your photo scroll down a bit to vehicle and then you should see the providers.
kdonnel
Metro Atlanta
2022 CA Route 1, 2020 Bolt EV
DevSecNetAIOps, General PITA
I think you need to be connected to the car when you do it so it ‘sees’ your EV
DRCal68
Gold River, CA
Thanks; I tried that: it shows 5 items:
Favorites
Guides
Offline Maps
Reports
Preferences
I cannot find ‘Vehicles’ under any of these.
Try following the directions here to ensure your car is connected to Apple Maps.
https://www.ford.com/support/how-to...ric-vehicle-ev-routing-feature-in-apple-maps/
Thanks! This worked well. This forum is great!
eastern refugee
Rich
california
insurance agent
When you do Apple car play does that make it so that you cannot use the other features of Sync like radio etc???
GDN
Far North Dallas, TX
F-150 Lightning, Tesla Model Y
Thanks for sharing, I wasn't aware you had to select the networks you wanted access to. Interestingly it allowed me to choose Tesla Superchargers, but I can't modify the type of plug/adapter I have. I'm guessing Apple is on top of this and will update it when the Superchargers open up.
TheSeg
Seg
San Francisco Bay Area, CA
seg.fyi
2021 Mach-E Premium EB-RWD (Built: Feb 2021)
I think the only thing it does not do is precondition the battery if you use the gps to find a charging station
Correct, the communication between the phone and car doesn't allow the concept of preconditioning at this time.
kdonnel
Metro Atlanta
Does Apple Maps correctly calculate the battery percentage on trips?
I have found the Apple Maps calculated percentages to be somewhat accurate initially. And then of course very accurate at arrival since the arrival percentage changes during the drive as data is retrieved from the car during the drive.
For example it might predict an initial arrival percentage of 20% and then as the drive progresses it might change slightly but I have found the ultimate arrival percentage is plus or minus 1-2% of the initially reported number. If it changes it is usually to the minus side meaning that if anything Apple maps is a tiny bit optimistic.
