Battery balancing service?
AliRafiee
Ali
Seattle WA
2022 Mach E GT - Grabber Blue
Software Eng.
They said it would cost $150.00 for the battery balancing.
If the recall involves the BMS, then I would do it. Otherwise optional. Ask them why they are recommending that.
On the other hand, if it’s part the recall, it should be free.
Phil-Springs
Phil
Colorado Springs
Mach E CA RT1 AWD Extended DMG 2022
Maybe it is more like actually physically recentering or balancing it to keep from wearing out the suspension unevenly.. sorta like tire rebalancing. I’m sure the primary symptom is range estimated that change rapidly.
What a joke.
AliRafiee
Ali
Seattle WA
Software Eng.
What a joke.
It’s balancing the charge between the cells.
VaporTrails
Southeast US
2023 MME GTPE Vapor Blue, 1995 Acura Integra GS-R
I can only imagine this is some kind of Charge to 100/ discharge to 0 shenanigan. I’m calling “meh” on this one. It is within the realm of possibility that this would cause your BMS to relearn 0. It is equally likely to relearn 0 wrong based on temperature and humidity or some such.
Trick.Mach-E
Trick
Earth
Old Raptor, Mach-E4x, New Raptor, F-250, Taycan.
Computer Nerd
I got the same quote for the battery balance job myself. Here's a tip, don't accept the first price the service advisor offers you. My service advisor saw I was hesitant and instead offered to kick me in the balls for only $50. Much better deal so I went with the ball kicking and saved money.
highland58
IT Solutions Architect
Blinker fluid ? However, it is very important to replace the air in your tires every 10k miles, especially for EVs
Yes with 78% nitrogen :rolleyes: Discount tire will do that on their tires every 6000 miles for free.
65MustangBoy
Les
Indiana
65 Mustang, 2023 Mach E Premium
And don't forget replacing those dreaded muffler bearings.
JohnFoxeSheets
San Francisco
johnfoxesheets.com
Retired Engineer
Be careful, the spin balancing is dangerous AF
Mach1E
I hope that’s not what they do. Both things (especially the discharge to 0) are bad.
And they have to drive your car for 300 miles to do it?
Yeah, pretty sure that wouldn’t be the process. Would take them 4 hours plus by itself to discharge completely.
The process likely looks like this-
Step 1- charge your car
strep 2- charge your credit card
Skip Towne
New Hampshire
Mach-E 4x Premium
I never change the air in my tires based on mileage. doing it seasonally is more important - winter air is different from summer air - just like gasoline blends.
