Battery depletion
Oneoone
Keith
Pennsylvania's
2021 mach e premium
Pc tech
Recently the dealer did a bunch of updates to my 2021 Mach E and now it seems my battery is reporting significantly less miles. I usually charge to 90% and use to get 171 miles and now getting 145. Has anything changed with the reporting of the standard battery?
The update probably just reset your driving history. The predicted range is just a guess. No need to worry.
For what it's worth, my current predicted range at 100% SOC is 110 miles.
At least the OP didn't say the dealer put in the wrong battery! ?
Yes. 21P22 has several things in it that would impact your displayed range.
- improved range in cold weather
- display range accuracy
The latter impacts the displayed range as it says. In addition, as stated prior, your driving history may have been reset. And/or the cold weather dropped the displayed range.
Of course, as has been posted many times, all that matters is the current miles per kWh that you're getting.
https://www.macheforum.com/site/thr...gram-21p22-software-calibration-update.11677/
Crilly
Dale
Hartland, Wi
Livewire prius prime Mach e. In 3 weeks if it was built yesterday
Reset ev Driving history.
Oneoone
Keith
Pennsylvania's
2021 mach e premium
Pc tech
Oh, ok - makes sense. TY!!!!
Oneoone
Keith
Pennsylvania's
2021 mach e premium
Pc tech
So it is still recomended to charge between 20-90% usually right?
Yes. If you use it regularly, you can simply charge up to 90% each evening. That's what we do.
