Can I specify a "default max charge level"
awp0
Aaron
boston, ma
MME Premium AWD ER
I'm a new MME owner and I feel like I'm not visualizing this correctly. I think most people want to specify a max charge level that's under 100% for most of their charging in general. I'd personally like to tell the car that 80% is the limit unless I tell it to go higher.
But is it true that I need to configure this rule separately for each individual charging location, otherwise it'll default to 100%? And if the car's GPS location happens to be a little bit inaccurate while at a saved charging location, then it might mistake this for a new location and go straight to 100%? This sounds crazy to me. Is there no way to make 80% the default for all charging unless another rule overrides it?
I'm still getting to know this car, so forgive me if I'm missing something obvious. And thanks!
Yes, yes, and yes. It’s dumb. Hopefully global charge limit is coming to the next SYNC version.
awp0
Aaron
boston, ma
MME Premium AWD ER
Oh man. This is brutal. But thanks for your reply. I was hoping I was missing something obvious :(
OON7
Evan
Yeah, I have a bunch of dummy addresses saved when the GPS goes a little wonk at my house and thinks I am down the street. Basically anytime it happens I save the address to set a max charge.
This is a great suggestion though and I wish it had it.
awp0
Aaron
boston, ma
MME Premium AWD ER
Thanks, that sounds like a good workaround to help ensure it stays consistent with home charging. I guess it also helps to just pay close attention to the app, to make sure it's targeting the correct charge level each time you plug in.
In practice it isn't that bad. Dumb, but workable.
Most people have consistent charge locations except when on a trip, and it is simple to set up a charge location. Just add it during or after you charge for the first time and then it will always remember it. And I think only one time my car didn't know where it was when charging, so I have never really experienced a incorrect max charge at a saved location.
And if it charges to 100%, it isn't a big deal. I charge to 100% on a weekly basis anyway. Daily it is 90%, but before I leave for my weekly commute I charge to 100%.
awp0
Aaron
boston, ma
MME Premium AWD ER
Thanks. Those are all really good points. I'd prefer not to think about it and just trust that it never tries to go above 80, but it's not the end of the world to spend some time plugging in the locations.
You can’t really “plug in locations”. You have to actually charge at each one.
awp0
Aaron
boston, ma
MME Premium AWD ER
Yeah, sorry, bad wording on my part. I'm aware you have to charge at a new location first, then save a configuration for it.
Keep in mind that if you are at a charge-for-payment public station, most of these stations will charge an insane amount per minute once the car stops charging but is still connected To prevent people from hogging the charging space all day. ??
Most will have some (fairly short) grace period. 10 minutes is common.
That was one of the benefits of the original DCFC charging curve - it was so slow above 80%, it never stopped charging! ?
This is a great point, and I noticed this as well. I was used to it slowing to a trickle when it hit 80%, but now it hits 90% before I realize it. You have to pay closer attention!
dmastro
Roseville, CA
2022 Mach E Premium AWD (ordered), 2018 Tesla M3
So you can't just program a standard % limit???
