kltye
- May 21, 2021
- Chicago
- IB MME Premium RWD
LVB issues are more than just loose bolts - software issues might prevent the DC-DC converter to charge the LVB until the car is fully "on", for example. I had to jump my car with one of those packs after I flashed it with FDRS because the LVB died in the process. In my old C-Max Energi, one day I walked up to it and it was completely dead for no apparent reason. Managed to get in with a physical key and jumped it. Never had a problem like that again. You don't have to get a battery with a bazillion amps to start some computers and pumps, but it's always good to have one around to double-check what the issues are when you're out "in the field".these type of products are designed to provide lots of amps, but just for a few seconds, to start an ICE vehicle... or very low amps for a *longer* time to charge a phone or run a 12v LED flashlight. Suitable for popping the Frunk, and perhaps enough juice to unlock your doors....
But ***NOT*** enough Energy to run an EV computer control system and computer for more than a few minutes if the HVB -> LVB charge system has failed and that is why the LVB is dead.
I would humbly suggest that carrying a 'jump battery' anywhere in a BEV is a waste of money and space. If you are worried about the dead 12v issues, you will be much better off to prepare for a significant energy transfer from a running vehicle with regular old jumper cables connected to your 12v 'connection points' for a good 20 minutes to transfer a meaningful amount of energy from the running vehicle to your (presumably dead) 12v battery... enough to get you to the dealership to figure out why your 12v is not getting charged.
5 minutes with a 2" hole saw will provide easy access to connection points so you don't have to remove plastic covers to get, or give, a jump. $2 plastic plugs available at any hardware store will make it look almost OEM.
https://www.macheforum.com/site/threads/how-to-add-access-ports-for-lvb-connection-points.4107/
