- Lee
- Jul 16, 2021
- Wisconsin
- 2022 Mach-E Premium AWD
- Sci/Eng
Well, you had a zillion low voltage codes, but the good news is no HVBJB codes. The HV warning was probably just because of all the low voltage stuff happening. If you start the car again and there are no error messages (other than the ABS/park brake) then I think everything will be fine now.Update: car started with jumpgot a message in the ford pass app that says,"High voltage battery warning, "the powertrain control system has detected that the system power supply voltage is lower than desired" is this a bigger issue or was it just the 12v?
