Adox11
- Aaron
- Sep 30, 2023
- Prince George, BC
- 2021 Mach E Select AWD; 2023 Mach E CR-1
Should note that the "high voltage charging process" referred to in the service bulletin attached means 120vac or higher. Even applies if car is not charging and is only plugged in for battery maintenance. ie you have max charge level set to 50% and SOC is 60% and you only plugged it in because it is cold out.Attached is the service bulletin that my dealer did in Jan 2023 after my 12v died. I had been driving this car daily since april 2021 before it became an issue. We had an extended cold snap I had the car plugged in at home and at work for a week or so before the 12 volt battery died.
