CarPlay and Climate/Other Controls?
rodhx
Rod
Alabama
Rivian R1T, Lexus IS300 autox/track car.
Thanks for posting these! They work great. Shortcuts for the hatch and frunk would be awesome! Especially the frunk once we get that enabled.
jRedondox
Jorge
Mach E
Business owner
I got all shortcuts working on my mach e! how do we add another car?
Behoff
Glens Falls, NY
2021 Mustang Mach-E
Here are some of the shortcuts. There are more and when I find them I will post it.
I used these exact instructions to get Siri to run these shortcuts on my GT500. They all work well. One note, the start shortcut will only work one time with Siri. In order to run that start shortcut again, you need to make sure you start your car with the kebob then it will work again. In other words, it only works once remotely with Siri until you do a normal start.
Required Shortcuts: Install these three in order and run each one as you go along to ensure you have your settings correctly filled out. The rest of the shortcuts build on top of these 3 so once they’re working, you should be good to go for the rest.
FordPass Settings (https://www.icloud.com/shortcuts/9bc1eb69fef84afebdf14c1e26db2166) - This sets up your account information as well as the VIN of the car you want to control. It also includes hardcoded values for clientId and applicationId which were pulled from the git repository.
Get FordPass Token (https://www.icloud.com/shortcuts/16b5984efea8462e9897c1e58a8d9560) - This uses your login credentials and returns an auth token.
Get Vehicle Status (https://www.icloud.com/shortcuts/75dfc5615d1f43e485866c12661b0e8d) - This returns a detailed JSON containing a large amount of information about your car and is used in many of the shortcuts below. I only built shortcuts that every vehicle should support but if you run this on it’s own, it outputs the JSON so you can look through what else is available.
Feature Shortcuts:
Start My Car (https://www.icloud.com/shortcuts/52e05449cdc24596959dca93ee6bf20c) - This will send a start command to your car. It typically takes 15-30 seconds before your car will actually start but you can check if it is running using the ā€œIs My Car Running?ā€ Shortcut below.
Stop My Car (https://www.icloud.com/shortcuts/4f8d3221632c4a8095cf8e9d66eeb6a5) - This will stop your cars remote start
Is My Car Running?(https://www.icloud.com/shortcuts/99105621a5b2406f91ef49ce173c9661) - This will let you know whether or not your car is running due to a remote start command.
Lock My Car (https://www.icloud.com/shortcuts/ba30bb2568f141a5b096a3b6ca377e76) - Locks your car
Unlock My Car (https://www.icloud.com/shortcuts/ab6172c868094a84b6f7d6a982959d7e) - Unlocks your car
Is My Car Locked? (https://www.icloud.com/shortcuts/ac1656d2cd9c411589cdbd413df67f17) - This will let you know if your car is locked or unlocked
What Is My Cars Range? (For ICE car only) (https://www.icloud.com/shortcuts/5c5bf7fc8cbd4e17893f5c36475cb437) - Range left in miles
How Many Miles Are On My Car?(https://www.icloud.com/shortcuts/254d268ba9df4e84b93380894dfe5567) - Odometer reading in miles
What Is My Cars Oil Life ? (For ICE car only)(https://www.icloud.com/shortcuts/c4eb2605a4fa4b8fb1fa8fd16541c965) - Oil life as a percentage
Where’s My Car? (https://www.icloud.com/shortcuts/cc151cb9229a49119814bd72b981be7b) - This opens Apple Maps with a pinned location of your car
What is the Range on My Car? (Mach-E only) (https://www.icloud.com/shortcuts/bcfd6f24e31e4a06a1ec1ffd2693ce4a) Range left in miles for the Mach-E
What is the battery level on My Car? (Mach-E only) (https://www.icloud.com/shortcuts/da0f53f31d4d46c48fc7b8bc5be4dd9d) This will let you know the battery level percentage of your Mach-E
What are the tire pressures on My Car?(https://www.icloud.com/shortcuts/7c705c978ec548dc9fe9af09ec879039) This will tell you all four tire pressures.
when I run ā€œget Vehicle Statusā€ I am getting a message that the URL is invalid. Could this have changed?
markboris
Sonora, CA
It hasn’t worked in months
Correct, Ford changed their API and mine stopped working middle of last year. It was a good 3+ years while it lasted. 😊
