Chargepoint Home Flex install (wired) - stripped wire prep?
grein002
Scott
Durham, NC
I've purchased the ChargePoint Home Flex and mounted it to the wall. I have a 25' run of Wireco 8/3 THHN metal clad (see here) from the 60A breaker in my panel. If you are familiar with the charger, you will know that the included power cord has flattened metal "pins" to insert into the snap-close connectors. My question is, should I just insert the stripped 8AWG into these holes, or does it make sense to prep the stripped ends, perhaps by flattening and tinning with solder?
First of all, #8 MC is only good for 50A with a 75°C termination temp. So you need to return the 60A breaker and get a 50A one. The EVSE will run at 40A. You also only need 8/2, neutral wire is not used.
Inserting copper wire strands into the ChargePoint terminals is acceptable.
ocdxfv
Matt
Orange County, CA
2021 Mach E, 2013 Toyota Rav4 EV
Retired radiology tech
I wouldn’t solder them. I used a wire ferrule.
I second what Mach-Lee said. If you needed to prep the wires in any special way for terminating, it would be spelled out in the installation instructions.
Stu H
Stu
Vacaville
2021 Mach E GT Pe; 68 Corvette, others....
I thought that the following is a good rule (Copper wire):
15 Amp 14 ga
20 Amp 12 ga
30 Amp 10 ga
40 Amp 8 ga
50 Amp 6 ga
60 Amp 4 ga
1 size larger (lower ga number) if using aluminum wire....
Did I miss something?
Aubury
Dearborn, MI
2023 Mach E Premium - Grabber Blue
15 Amp 14 ga
20 Amp 12 ga
30 Amp 10 ga
40 Amp 8 ga
50 Amp 6 ga
60 Amp 4 ga
You can't use aluminum directly in the chargepoint install. You would have to pigtail to copper before it goes into the EVSE.
david_quick
Bremerton WA
2023 Mach E GT
this is one thing I noticed when I converted my EVSE from plug in to hard wired. The 14-50 it came with did not have a neutral. Now that has me wondering if they all are that way.
grein002
Scott
Durham, NC
240V equipment doesn't need a neutral unless it needs 120V for some of its internal functions. If the EVSE doesn't need 120V, it has no internal connection for neutral, and they can save some $ by omitting the conductor / prong.
orangethunder
On order
No need to flatten the wire. Just let the wire clamps do their thing.
But your breaker is too big for 8 gauge wire. Highly recommend you swap out with a 50amp breaker (which will charge at 40 amps, i.e. 80% of breaker size for use by continuous loads).
grein002
Scott
Durham, NC
Yeah, I've ordered 6AWG MC to replace the 8AWG.
Yes 6/2 is what you want for a hardwired 60A breaker. You have to look up the ampacity for the specific type of wire you’re using.
