MellowJohnny
- Christian
- Nov 16, 2021
- YYZ
- 2022 Mach-E Premium AWD
- Solution Architect
*** UPDATE *****
After @Mach-Lee ran my VIN through FDRS it seems more likely that this is an issue with the on-board charger, and not an issue with the ChargePoint unit.
In case anyone with a Home Flex encounters the same behaviours:
Plugged the car in Friday night and within a few minutes the Ford Pass App threw a charging errors. Went outside, and sure enough it has stopped. Plugged it back in, charging started, and then a few minutes later...another fault. Repeated the unplug / plug cycle one more time...fault. So to eliminate the car as possibly the culprit I went to the mall and used a L2 public charger - no problem. Tried the Ford portable charger...no problem. So it seems like it's not the car.
So I unplugged the unit and started again. Same result. Rebooted from the App...same result. Left it plugged in for a while and noticed it was charging, stopping, charging again, stopping again...etc. The charging graph in the ChargePoint App looked like the Rocky Mountains. Seems completely different from the derating bug, as it ramps up, then stops. Then five minutes later the cycle starts all over again.
Called ChargePoint customer service on Saturday (who were great), walked through a bunch of troubleshooting, re-installed the App, etc...nothing helped. Ultimately they will be replacing the unit.
So if you have a Home Flex and it seems like ChargePoint wants to break up with you, just know it's probably them, not you
So while I wait it's back to the Ford portable charger...at least I'm "orange & blue light" charging.
