Charging problems -- always going to 100% capacity
Lev270
Portland
Ford mach e
Ok dose anyone else have this issue? No matter what I do and how I set up my car to charge, it always charges to 100%. I have tried everything.I have set ut up exactly like I have been told 20 different times. But when I get up in the morning it is at 100%. I have set it up with only the car, and only my phone. I have done two full Resets in the car. I have deleted the app and charged the car with no phone linked to it. I have tried only using the phone. And it always charges to 100% when I go to bed it is set to 90% charge but nope it goes to 100%. I have reset my location many times. I gave disconnected from WiFi when changing. Help please
WiFi has nothing to do with it.
Save location in CAR. Set hours and limits.
hybrid2bev
2026 Rally
Make sure FordPass is set to ā€˜Use Preferred Charge Settings’ and not set to ā€˜Charge when plugged in’.
Ford Mustang Mach-E Charging problems -- always going to 100% capacity IMG_4048
JerryR
Jerry
Suffolk, VA
2022 Ford Mustang Mach E, AWD
Retired Engineer
I had this problem when I first received my car. In the Ford Pass app, make sure you don't have the "charge when plugged in" enabled. It will continue to charge until it reaches 100%. Enable the "preferred charge settings" instead. It is located under Charging, then "charge settings". Then when you push the charge to 90% it should not go beyond that. Hope that works. I think someone already beat me to this answer.
Callmekarri
Karri
2022 Mach-E GT
Web Manager
Is the setting you’re talking about in the car or the app?
Noggieponni
Norge
Mache-e
did you find out what the issue was?
I now have the same problem, after an update the charging is all fucked up. I can set the car to say 85% and apps are all locked in the same, but the car keeps charging to 100%.
useless online help desk say go to dealer, but dealer doesn’t answer the ph and online booking is a wait of 2 weeks!
