Always charging to 100%
RedStallion
Mach-E, et al
@Ford Motor Company it's time you give a option for a global charge limit for the car. I think this makes life a lot simpler
They should go a step further and allow setting any charging session to any target and any schedule after connecting the car. That's kind of an obvious thing to do. I'm surprised Ford software is designed so unprofessionally.
When I travel I may be charging at various locations over night, it's ridiculous requiring to save them with a schedule and a target.
Tampamike
Tampa, FL
ā€˜24 Mach E Premium RWD
Well as I went back and checked the app it has switched on its own again to 100%!! It charged no problem and now it’s back doing it again lol dang it! And it’s been on the charger for 3 hours and kept saying charging at home, 85% now it says charge to 100. What the heck I give up lol
Is it actually charging past your desired percentage or does it just look like it is going to when you look at the charging details in FordPass? Let it finish charging and see where it stops. Seems to me when I look at ā€œcharging detailsā€ on FordPass while it is charging, the display seems to indicate something other than what it is doing. However, it always charges to my set 90%.
Elena
Elena
Elena
Mustang Mach e
Yes, it keeps charging past my settings. It worked for a day with one of these suggestions I followed and then last night it stopped. I checked settings before I went to bed and it said charging at home 85%, couple hours later I looked and it changed it to charging at 100%, then at the bottom is said resume schedule so I clicked that and it went back to 85% (my settings) woke up this morning somehow it got over rode and it charged to 100
Howard
Howard
West TN
'23 Premium RWD ER CG Mach E & '25 Blazer RS EV
Elena, sorry that my suggestion didn't work. Hopefully, software folks will get it figured out for everyone at some point.
83girl
Stephanie
MachE Premium
Scientist
That’s a great idea. I do have home set up in the navigation the issue is that the GPS when charging thinks I’m at my neighbors house. So when I set up ā€œhomeā€ it’s at a different address then what my home really is. Unless I put ā€œhomeā€ as my neighbors address and see if that changes it.
I had the same problem with my 2021 for about a year and a half. My address would not show in the ford app, and it always assumed I was at my neighbors house. Glitch that somehow fixed in an update last December I think it was.
DaMeatMan
Toronto, ON, Canada
Hi!
I am needing some advice. I feel like I’ve read and done everything has been suggested and my car is still charging to 100%. First off the gps in the car thinking I’m charging my neighbors house. Previously it has never been my correct address which was fine because it always recognized me at ā€œhomeā€ and did my charging preferences. I have deleted, reset, reentered you name it. It starts by saying I am charging at home (will attach photo below) but then I wake up and it says I’m not charging at home and charges to 100. (Attach second photo) I’m at a loss at what to do.
This is just one of those things where Ford decided to re-invent the wheel with wonky logic, instead of doing what every other EV manufacturer does by allowing you to specify a GLOBAL setting that limits charge rate ANYWHERE you charge.
They still could have implemented location based charging logic that overrides the default global setting (it the customer chosesbto add a location entry).
But clearly some genius at Ford decided it would be a great idea to FORCE the customer to muck around with location settings FOR EVERY LOCATION THEY CHARGE AT, just to prevent the battery from charging to 100%.
Obviously my sarcasm here is an indication that this is a long-standing issue that Ford chooses to IGNORE, despite it being so incredibly simple to fix. So for now your going to do all sorts of wonky things like setting your "home" address as your neighbors address, or the house 2 blocks away.. essentially set it to wherever the GPS thinks you are and that should fix it (for your home location anyway).
That sounds like somehow the car is getting a ā€œCharge to 100%ā€ signal from FordPass just as if you tapped that button.
Since know you didn’t do that, there are three possibilities that I can think of:
1. Your car is connected to FordPass on someone elseā€˜s phone and theyā€˜re messing with you. (Not likely)
2. FordPass on your phone is whacked and sending the signal. You could rule this out by deleting FordPass from your phone and doing a charge session while uninstalled.
3. There is a problem in the SOBDMC module on the car. See post 20. I think this is the most likely scenario.
Shayne
Northern Ontario Canada
2021 MME4x Prem
SOBDMC module resetting itself is my guess. Keeps giving you hope but then resets and goes to 100%. Sometimes holds for scheduled time sometimes it does not sometimes it stops at set % but will always reset and charge to 100%. The end result is it does not work. Your best to see if it can be reproduced at the dealer. No one is going to fix it here if you are sure the settings are right. The idea of disconnecting the 12V for 10 minutes is BS let your dealer deal with it. Schedules, charging and departure, are hard for Ford on mine.
As noted my FP and Sync have 2 different addresses neither are at my home where it is. Was not the problem and both are still wrong. Forget what the address says take whatever it gives you when adding the locations. It uses the coordinates and use to display them when adding. I have not added a charging location lately but if you plug the coordinates displayed when adding the location into google map it will most likely be really close to where the car is. Just set it and forget it until that does not work ;)
Elena
Elena
Elena
Mustang Mach e
Thank you ? I called and got an appointment with someone but they don’t have anything for another month ??ā€ā™€ I think it maybe something with the app not communicating with my vehicle because every now and again it will say it’s partially responded. I reset my keys and the app won’t connect to my so I can’t even get the pakk key right now. It’s so weird cuz I’ve had it since the beginning of the year with literally no issues but I am known to have technology always break on me so it explains why it’s doing it ?? I appreciate all the suggestions and help!
Shayne
2021 MME4x Prem
That is normally the case start playing with things until you have a number of other problems. As long as you know you can not fix broken hardware playing with software you should be good. Make and hold the appointment in case you need it still a month from now.
Tampamike
Tampa, FL
Right. That’s what I was saying. Just plug it in with your current settings. Go to sleep and forget about until the morning. Don’t look at or change anything. See what happens. When I look at my settings, it doesn’t always look right but it always does what I set it to.
laika
Sean
Brighton, UK
Mustang Mach E ER RWD
MD
I have had similar problems for almost a year now.
there was an update about 10 months ago and from that point I never got the schedule charge to work.
I went through every suggestion listed in this thread. Sometimes it would not charge at all and it was a lottery if I woke up with a charged car.
it went back to the dealer 4 times and they just said it was fine. I sent them close on 100 screen shots and videos of me setting the schedule on the app and in the car and then the results next day. All they would say is it works fine for them and it must be my charger. Well the charger just delivers when it’s asked and it worked fine for 5 months.
I now have a Zappi and I schedule my charge through that. Downside is that I can never charge to a set level unless I do the maths. Upside is that it doesn’t randomly charge on more expensive electric.
I was most disappointed with Fords customer service as they just had no sympathy and just told me to keep taking it back to the dealer.
Good luck in resolving as I never managed to.
Elena
Elena
Elena
Mustang Mach e
Thank you! I’m so sorry. Yeah it seems something somewhere isn’t communicating with my car. I can’t even add the PAKK key anymore, just says it can’t communicate which leads me to believe there is some sort of error in software. It charged the other day to 85% then at some point charged up to 100 again. I’m hoping I can get this resolved. If I do I’ll post it ?
I'd suggest you go back and read what I wrote in post #15. The issue here is with FordPass, not the car, IMO.
Elena
Elena
Elena
Mustang Mach e
You are assuming I did not do that already. I don’t disagree with you it’s probably the app, but I’ve done all that and it’s not responding.
