Charging Rate for 2023
dtonn
Chrysler 300s, Mach E Premium AWD ER
Just got my Window Sticker and my Premium AWD EXT Battery shows "UP TO 115KW DC CHRG CAPABL" which is much less than the (short) 150KW rate that we have seen in the past.
Is this maybe conservative messaging and does not represent an actual reduction in peak charging rate, or is it an actual change to be even more cautious with the battery?
Does your window sticker also show that you have the extended range battery? Can you post a picture of it?
dtonn
Yup, here you go:
Ford Mustang Mach-E Charging Rate for 2023 1669047943974
dtonn
Seems like it could simply be a mistake that indicates the max charging rate for the smaller battery.
Agreed, hope it's a mistake.
machefan2022
Brent
2022 Mach-E CalRt1
My guess would be another casualty of the HVBJB issue.
mcotton
2023 Mustang Mach-e ER eAWD (Vapor Blue)
Where did you get the window sticker? I have a Delivery date of 11/27 - 12/2 and haven't been given anything like that.
I would say perhaps it states that as it is under the standard equipment section.
Check the 2023 Tech Specs and see what they say.
Agreed. It would have been nice to mention the upgraded charging rate along with the extended battery option.
Howard
Howard
West TN
'23 Premium RWD ER CG Mach E & '25 Blazer RS EV
The up to 115KW charger is listed under the standard equipment on window sticker. If I am not mistaking, the Extended Range battery package includes upgrading the charger to an up to 150 kw charger but just doesn't specifically call it out. I don't recall seeing where Ford changed it.
Howard
Howard
West TN
Just finished looking at tech specs for 2023 models. Clearly states up to 150 kw DC fast charging capability on extended range battery. Here is a link to the web page:
Mach-E Specs (Aug. 25, 2022) (macheforum.com)
Link is to another thread here on forum. Thanks to folk(s) that originally posted it back in August.
I just looked at a random window sticker from a 2022, and it looks like they didn't specifically call out a charging rate.
Ford Mustang Mach-E Charging Rate for 2023 1669054831913
Howard
Howard
West TN
My 2023 premium with ER battery window sticker shows the same as the OP's.
machefan2022
Brent
2022 Mach-E CalRt1
My 2022 sticker calls out 150KW DC Fast Charging
