Chimes upon startup
EagleDave
San Francisco Bay Area
2021 Mach E
How do these seatbelt chimes work with remote start (on an ICE or a BEV)? Does it constantly beep until you get to the car and climb in and buckle up?
No, because it knows no one is in the seat. Same reason it doesn't chime for the passenger, that isn't sitting next to you...
DevSecNetOps, General PITA
Oddly I sat in a parking lot for about an hour the other day (20 min drive to my kids Krav Maga class that’s 45 min long so I might as well just wait). Upon key on I got old school start up chimes. Never heard these ones before. I’m thinking it might have been the seatbelt chime you speak of. Might have been the first time I ever started it without being buckled.
phil
LS400
Seat belt chimes are supposed to get more annoying this year due to updated IIHS guidelines that require them to ding almost continuously until you put your belt on. Looks like Ford may have implemented this for 2023 models.
This is among the best features of my '98 Lexus: no seatbelt, no annoyance - blissful silence!
Fins160
JP
Tempe, AZ
2022 MachE Select C/T Dark Matter Gray
My 2022 has the seatbelt beep, but it’s slower only 4 times, and nowhere as annoying as the video you shared…
phil
LS400
The seatbelt warning can be disabled:
Ford Service Content
No, it cannot! At least it did not work for me, not entirely.
I only get four of those chimes, when I start without fastening the belt. Plus, there are intermittent chimes as long as I drive, until I fasten it. If I fasten first, no chimes.
So I disabled the warning chimes as instructed. The intermittent chimes are gone. But the four initial startup chimes remain, if I have not buckled. Is that how it's supposed to work? Partial disabling of the seatbelt warning, not complete disabling?
Good question. I disabled them in my Lightning and the next time I started it - no chimes. Shortly afterwards, I had to pull a fuse to reset the BCM which reset the chime. I need to perform the procedure again.
I haven’t tried it in my Mach-E - the Lightning is the only vehicle I really need it disabled in. In and out of the truck when Iā€˜m at the farm…opening gates, etc. I never drive on a public street /highway without a seatbelt.
Chainspell
Erich
'21 Premium 4X, '23 GTPE
Same for me. As far as I know this procedure does not disable the start-up warnings. Maybe with FORScan? I always wear my seatbelt when driving, even across something small like a parking lot. But this feature is really annoying to me as I have always turned car on then immediately buckled. Turns out doing that for decades is hard to undo.
I pulled the seatbelt buzzer from my T/A to save weight. Could not hear it over the exhaust anyhow. I don’t care about the chime in the MME since it shuts up as soon as I buckle the belt and the Blazer never had one to start with. ?ā€ā™‚?
