ricksta6
- Rick
- Mar 29, 2022
- Chicago, IL
- 2021 Mach-E Select Rapid Red
As the title says, I'm curious if the Mach-E's DC fast charging speed could be improved from the rated 150 kW to 350 kW via a software update, or is there a physics/design limitation that would make it impossible with the current 2021/2022 models?
Obviously the charging curve itself can be improved as they've already done so to bump it to 90%, and there are very few 350 kW DC fast chargers out there, so this point might be moot, but I'm wondering what's stopping such an update if it is possible. Not that the math is difficult but it would make it easier for most folks to compare the Mach-E to the charging speeds found on the EV6 and IONIQ 5 if it were possible.
