- Lee
- Jul 16, 2021
- Wisconsin
- 2022 Mach-E Premium AWD
- Sci/Eng
If the dealer doesn’t properly balance the new modules before installing, you will have problems with not being able charge to 100%. It can take like 6 hours to balance a module, so some dealers will cut it short for time. But as you found the problem will slowly correct itself over a period of weeks. I recommend charging to 90% daily until the battery is fully balanced.It's funny that you said this just now! I was digging into this a bit more on my own and found this:
SSM 52039 2021-2023 Mustang Mach-E, 2022-2023 F-150 Lightning/E-Transit - Unable To Achieve 100 Percent State Of Charge After HV Battery Module Replacement Some 2021-2023 Mustang Mach-E, 2022-2023 F-150 Lightning/e-Transit vehicles may exhibit a concern where the vehicle is unable to achieve 100 percent state of charge immediately after high voltage (HV) battery module balancing and replacement. This may be due to the battery energy control module (BECM) adjusting the cell balance (conditioning) of the battery module and should be corrected within 22 days. If the vehicle otherwise functions as designed with no related diagnostic trouble codes (DTC) setting, this concern will be corrected automatically with no further actions required by the technician.
So yeah - this is a situation where the dealer didn't share a warning about this. So all's well that ends well, I suppose. However, the "22 days" part is a "wow, that's a long while" item. But NBD - good to know that this is both normal-and-expected!![]()
