DCFC preconditioning is it coming????
So this would be some kind of control in the car that you’d manually activate to say “I’m heading to a DCFC charger now; start preconditioning the battery”?
You wouldn't manually activate it. It will automatically activate when you set a DCFC station as your destination or a waypoint in the Nav. In the Ioniq 5, it will only activate if you're within 30 miles of the DCFC station and your SOC is above 20%. Hopefully, Ford's implementation won't be quite as restrictive. And I sure hope they're planning to have some kind of indicator that shows when it's operating.
hybrid2bev
2026 Rally
That's unfortunate, but not too surprising as the Ford nav is a subscription service that people will need to start paying for from year 4 on. They probably want to make it more attractive to get people hooked on it, hoping it can generate revenue for them. Which will be tough to do when there's Android Auto and Carplay nav systems that work well and remain free.
A manual precondition button would be nice, but it's not a big deal to me. We do a lot of road tripping and a lot of DCFCing (almost 25k miles worth now), but DCFC charging times really haven't been an issue for us. Saving a few minutes would be nice, I guess, but eh.
I thought the Ford Navigation was included in the purchase of the car. It's the navigation connected services (weather, traffic, parking info, basically any real time status info etc.) that is covered by a subscription. Just using the onboard Nav as a GPS should always work even without connected services subscription.
dbsb3233
TimCO
Colorado, USA
Batteries charge slowly at a DCFC when they're cold. Preconditioning will heat up the battery when the car knows you're on your way to a DCFC so that it's warm when you get there and can charge faster.
Do we know if the warmer battery makes a significant difference in efficiency too? I'm guessing it probably does some, but not enough to fully offset the energy used to warm it up (otherwise Ford would automatically be doing it more than they already do).
I thought the Ford Navigation was included in the purchase of the car. It's the navigation connected services (weather, traffic, any real time status info etc.) that is covered by a subscription. Just using the onboard Nav as a GPS should always work even without connected services subscription.
That's my understanding as well, though you won't get status updates from the DCFC stations without connected services. Let's hope that preconditioning isn't tied to that subscription.
I believe you're correct.
dbsb3233
TimCO
Colorado, USA
You're probably right. I really don't know what features will disable when the trial ends. I'm guessing it will somewhat mimic the way it's worked in Ford cars for years (where you get a static map but then they try to sell you $149 updates). But not sure.
Also unclear whether the designation of a destination being a DCFC (thus eligible for this preconditioning feature) would require such connected services.
Ford Connected Built-In Navigation is a 3 year trial (Ford's words) of navigation services. After completion of trial, if not renewed it will revert to the embedded offline navigation. Features include "accurate maps, thoughtful points of interest, charge locations, real-time traffic and road condition updates, almost instant rerouting options". Note that the connected navigation updates full map yearly and "home zone" quarterly. It also provides navigation in "cellular dead zones".
If "charge locations" are completely removed after the trial ends, that would certainly kill preconditioning. But the bigger loss would be route planning with charging stops.
Phil-Springs
Phil
Colorado Springs
Mach E CA RT1 AWD Extended DMG 2022
The laws of thermodynamics dictate it must be a net loss . This method is a trade of energy for faster charging times. The value depends on how much you value your time.
Right. That will always be the case if the power to warm the battery is coming from the battery itself. If you can get the power from somewhere else (like when plugged into Level 2), you can increase efficiency without losing any battery power. That's why setting a departure time while plugged in will get you better range.
dbsb3233
TimCO
Colorado, USA
I don't think that's accurate, otherwise Ford wouldn't have a BMS system that warms/cools the battery pack at all if it were always a net loss to warm/cool it.
I think it's really about when/where it shifts from a net gain to a net loss. And I presume Ford has already found those points and set the BMS parameters accordingly.
KissOD
Kiss
San Antonio, TX
2021 Mach E (MME)
Program manager
...first world problems, right?
dbsb3233
TimCO
Colorado, USA
I don't think it's a simple 1:1 correlation like that though for this case. That would be the case if we were just adding/subtracting electricity alone, but in this case we're talking about how some heating/cooling of the battery physically allows the electrons to flow better within it. There likely is a point where some heating/cooling produces a net gain (thus why there's a BMS and fluid running through the battery pack to keep it within a temperature range). But they've surely already optimized that for us via the BMS.
