Does EXT and STD Range have the same motors?
solarity
Rochester, NY
2021 F-150 Platinum; 2021 Mach E Premium
We are getting the STD Range AWD Premium Mach-E, though I see the EXT range is about 0.4 seconds faster on the 0-60s.
I am curious if they are nerfing the acceleration of the STD Range via SW to give people a second reason to swallow the $5k up charge for about 69 extra miles?
gnaark
DC Metro
First Edition Rapid Red
There's a difference of HP between Standard Range and Extended range.
428ft-lbs and 266 HP vs 428ft-lbs and 346 HP
not sure if it's software throttled though - it may be done to be able to guarantee the range.
ski99
Troy
Albany, NY
Volvo XC90, Prius
The larger battery can handle a higher energy discharge rate. More energy transfer to the motors = higher torque and power.
That said, it is also being managed by software. Ford could choose to allow a faster discharge rate on the smaller battery and trade off some battery life.
JamieGeek
Southeastern Michigan
spareelectrons.wordpress.com
The difference isn't the motor: Its the battery. The smaller battery cannot provide the current the larger one can, hence the lower numbers.
silverelan
Seattle
The SR is a 75.7kWh pack (68kWh usable) which is objectively quite big so it shouldn't be a big leap to enable additional current to match the ER pack.
If the SR AWD motors had the same power as the ER version, it'd probably drop a decent margin off the 0-60 time.
Cool. I always wondered why the SR, with a lighter battery pack was actually slower out of the blocks. The more you know ?
I think you are confusing kWh with kW. Easy to do....I get confused all the time with that....
The extended range battery pack has 1 more module than the SR pack so it is able to provide more watts. More watts=more power. kW is power.
silverelan
Seattle
Maybe I'm not phrasing it right. Lemme try again.
What I'm saying is, if the 75.7kWh pack could discharge its electrons faster, then the SR AWD motors could make use of that to match the power output of the ER AWD. So 346hp for the SR would improve the 0-60 time and easily beat the ~5 seconds the 4X can do.
Sure. But the SR battery has fewer cells, which is why the max discharge rate is lower. It's also why the max DCFC rate is 115kW instead of 150kW.
silverelan
Seattle
Gotcha. Seems like it's something that could be changed in the future to improve the ability to kick the power output up in the SR AWD.
Even if it's possible, I highly doubt it's something Ford is planning to do.
The SR pack would need higher voltage to discharge faster than the EX pack. But yes, increase the voltage and it could be possible I suppose....
