Does this make me the first lifted Mach-E?
Looks well done, natural look to it. Next we’ll start seeing BFG All-Terrains, tubular bumpers with a winch, and off road LED lights ??
stock clearance is plenty for me
Ford Mustang Mach-E Does this make me the first lifted Mach-E? ePony 20230513 shuttling blocks
Mike_Hawk
San Diego, CA
2022 Mach-E Premium Extended AWD (Space White)
Hi Mike, any updates on the car? Now that you've had it a few weeks, any changes to your assessment?
If there are any changes to my assessment, it's been more positive. No ragrets. The ride quality and cornering is fine, the extra ground clearance has been comforting, and many people have said the lifted look is a great match to the car. It "looks" like a slightly bigger car too.
The increased clearance has already helped with parking beside high curbs on my last two road trips. There was a curb in Los Angeles that I cleared by less than half an inch when the passenger door was opened. A stock-height Mach-E would've absolutely smacked it.
4sallypat
Pat
www.kudo-ume-farms.com
Network Tech
I love it! Makes it more practical for curb hazards plus getting in/out for those us who are older with neck & back arthritis...
So far only 1" lift springs available....
For the same money, I'd rather get the 1.5"
Ford Mustang Mach-E Does this make me the first lifted Mach-E? Screen Shot 2023-06-25 at 9.08.23 AM
Mike_Hawk
San Diego, CA
Those are the lowering springs. Hopefully the Pro-Lift-Kit becomes available soon.
Totally agree with the curb hazard avoidance!
4sallypat
Pat
Network Tech
I filled out Eibach's R&D form - hoping they contact me.
This was a really good idea for the off road look that I was looking for.
Mike_Hawk
San Diego, CA
Any idea when these will be released? I only see the lowering springs on website.
It's up to Eibach. I'd definitely contact them and show interest, hopefully they'll be inclined to release it sooner.
Coffs
PA
Mach E, Explorer, Busa
No it's slightly larger than the factory size. Usually up to 3 % difference is acceptable
The problem with 19" OEM rims is that they're only 7" width so you can only fit a max rubber width of 225.
tuminatr
Saint Paul,MN
2021 MME GTPE
sales
No, and here is a good way to figure that out. Use Tire Rack as a resource look up the tire size and click "specs"
The minimum width required for a 235/55/19 is 6.5". You could actually put a 245/50/19 on the 7" wide factory rim
Ford Mustang Mach-E Does this make me the first lifted Mach-E? Screenshot 2023-09-22 072220
Coffs
PA
Sorry for misleading anyone... Google lied to me
Ford Mustang Mach-E Does this make me the first lifted Mach-E? 1695388300102
tuminatr
Saint Paul,MN
2021 MME GTPE
sales
Tire racks is going to be much more accurate as they get that info from the tire manufacturer. You will also notice there are small differences by manufacturer and model.
A 7" wide rim is from the inside of the flanges. So if you measure the outside flange(edge) it's likely a little over 7.5".
YunniorO
Jacob
Westminster, Colorado
2021 Mach-E Premium AWD (Job 1)
I was the test vehicle for Eibach's prototype Sportline lowering springs AND lift springs.
In the end I decided to go with the lift springs since I was already apprehensive about the stock height especially with the low doors opening against curbs/sidewalks and clearing those pesky tall concrete stops in parking spaces.
Average of 1.5" lift (front 1.6" and rear 1.5" I believe). I never really had an issue with the "bounce" so I can't really say if it improved or got worse, however the extra clearance has been nice so far and adds to the "SUV" feel. I forgot to ask if it's a different spring rate, so I don't have that answer yet.
Also, I didn't notice a significant reduction in range but I've only had it for 1 solid day so far and I feel the height increase would outweigh any range reduction.
For those looking for some height and clearance, I'd recommend it when it goes into production.
I have to admit, I was a little scared for what I was about to see before I clicked into the post, but this actually looks nice and natural.
DevSecNetAIOps, General PITA
The overall travel would still be the same. What a spring with a higher static ride height would do is give more compression travel before hitting the bump stops and give less extension travel. ??
The 'problem' I see with at least the ER cars is there is zero give to the suspension a low speeds and low impact. What I wish i could solve is the street cracks/imperfections, water access covers, little dips and imperfections. Driving through a costco parking lot, loaded with glass crap in the back of the car you are alerted and get to feel every single imperfection as the tires are the only thing that gives at all. If you deflate them below, say, 35 all the sway bars and shocks can't help as the car pogo's side to side on the tire sidewall. Above 35 you feel everything under 5mph. I tried to think of a dual rate spring (an actual dual rate spring not these, where theres 2 springs at different rates) but theres no room for it in the stock set up, and near impossible in the front.
Yeah, a progressive rate spring with more progression from soft to stiff would help. Velocity-sensitive damper valving would help those issues too. Unfortunately neither is available yet. ??
tuminatr
Saint Paul,MN
2021 MME GTPE
sales
You can go a long way by lowering tire pressure. In most cars the tires absorb much of the impact force. When you have the tires inflated to 40+ psi they don't. The bumps, potholes and other imperfections transfer to the suspension & chassis. If you upsize your tires and lower the pressure it's much better
Think about the MME Rally with 235/55/19 XL 105. I haven't seen the spec yet but I bet they inflated those to 36psi. That translates to a much less harshness that would be required for a rally car
