Door Key Pad opens the Frunk!
PilotMark
2022 Mach E Extended, Mini Moke, FRS, Prius, FJR, 1966 Shelby Mustang
Does your Frunk open with the #7?
Have you seen this?
I accidentally added the #7 after I entered my code to unlock the Mach e and i heard the latch sound for the Frunk twice and sure enough the Frunk was opened. I have duplicated this several times.
I tried all the other numbers to see if I could open the back hatch. But no. Only seems to open the Frunk.
Interested to know if you have this too or am I just special?
It is fun experimenting and learning.
Yes, that's a standard feature.
It's also in the manual.
PilotMark
PilotMark
Thanks,
I didn't see it in the manual.
Is there a code for the back hatch?
Yes, despite what @ChasingCoral says, you are special, Mark. :clap:
5-6 opens the lift gate for my ‘21 Job2 car. 7-8 opens the frunk. ?‍♂?
J&S K
2021 Ford Mach-e
There is a manual?
And 8 + 9, locks the MME. Nice to know if want to lock the car when running. Like when dog is in the car when run into a store. Be nice if there was a published list of all the codes, short cuts, in one place.
ToOldForThis
2021 Mach-E Premium 4X
Technical Analyst
Ford says 5-6 will work for the trunk. But, to the best of my knowledge, it doesn’t actually work.
I have the same problem. 7-8 opens the Frunk, but I have never been able to get 5-6 to open the rear hatch. 2021 MME Job 1.
JeffGo
Washington, USA
2024 MME GT in Eruption Green
Not in my copy of the manual (2021). Only 3-4 to unlock, and 7-8 & 9-0 at the same time to lock all doors (or just press the little lock, which is also not mentioned).
Jtbuster
Brian oConnor
Calif
Mach e
B PILLAR KEYBOARD:
ENTER 5-digit personal CODE to unlock car, then press circle to OPEN driver's door
ENTER 5-digit personal CODE to unlock car, mirrors swivel, then press 3-4 button door opens
ENTER 5-digit personal CODE to unlock car, mirrors swivel, then press 5-6 button tailgate opens
ENTER 5-digit personal CODE to unlock car, mirrors swivel, then press 7-8 button frunk opens
OP doesn’t have a ’21. ‘23 manual has it.
