- Jul 1, 2021
- SE MI
- 2022 Mach-E Premium 4X, 2022 Lightning Lariat ER
Updated 11/9/22.
Once you use up your 250kw of free charging, you will likely use EA chargers on trips. In September 2020, EA started switching from per minute to per kWh fees in states where they are allowed to do so. They are trying to change all states to per kWh, but that takes lobbying.
Their rates are as follows:
Per kWh - 43 cents, 31 cents for Pass+ Members plus tax
Per minute - 32 cents, 24 cents for Pass+ Members plus tax - there is a lower rate for vehicles that can only charge at 90kw, which is determined by what the vehicle communicates to EA. Therefore, we pay the higher rate. Once the session begins, the rate doesn't change.
Pass+ is $4 per month, and you can downgrade anytime, which is effective when your month ends. You can upgrade anytime, it takes effect immediately.
As an example of the difference, on a recent trip I drove 625 miles from SC to Michigan. Started with 100% from the hotel. All stops were per minute, except the last stop in O_io where I needed to charge a lot to get to 95%. Two stops in KY, one in O_io. The cost for the trip, not counting the fill at home afterwards, was $33.77 including tax. Had all 179kW been per kW, it would have cost $55.49 plus tax. Had it been per minute, it would have been $24.00 plus tax. That's a huge difference.
The following states are per minute states:
Alabama, Georgia, Kansas, Kentucky, Louisiana, Massachusetts, Mississippi, Montana, Nebraska, New Hampshire, Pennsylvania, South Dakota, Tennessee, Texas, West Virginia, Wisconsin, and Wyoming.
These states currently have no EA chargers, and any state not listed is per kWh:
Alaska, Hawaii, and North Dakota.
As a forum member noted, if you're in a per minute state, you may not want to use your free charging up, because the effective rate per kWh at 24 cents per minute MAY be below your cost for electricity in your home (for example I pay 12.5 cents per kWh, so if the EA charger gives me 2kw in a minute, that's basically my rate). To not use P&C, turn it off in the FordPass app, then use your EA app to charge. You cannot change the setting if you have already plugged in.
If you notice an EA charger not providing you with fast enough charging, try moving to another charger. Sometimes you can go through several 350kw chargers getting slow charging, and find that the 150kw charger is providing over 100kw speed.
Report bad chargers via the FordApp (they say they added this ability to a recent release), the EA app, PlugShare, and/or call EA. Only by communicating issues will things improve.
Hope this helps.
Hope this helps.
