spgordon57
- Steve
- Aug 22, 2022
- Moraga, CA
- 2022 Ford Mustang Mach-e
I have a '22 MME Premium Extended Range, with 6,200 miles on the odometer. It has recently developed these electronic issues:
Thanks!
- When approaching the car I often first open the rear drivers side door to put stuff in the back seat. Even if the "open" button on the door is lit/unlocked from sensing my presence, the rear door won't open unless I open the front door first. Doesn't happen all the time but often enough that its annoying.
- When turning the car off, the headlights used to stay on for a couple minutes before turning off. Now, they stay on for about 20 minutes and you can hear the front motor make a whirring sound.
- When turning the car on while in the drivers seat, the seating position should return to my personalized setting. Sometimes it does but more than half the time, it doesn't, and I have to hit the present seating position on the door. Again not serious but its annoying.
- Nos. 1-3 occur more frequently in lower temperatures.
- Ford has been trying to upload software update 4.2.5 (heating system improvements) for the past week. Each time it fails, whether I'm doing it manually, or allowing it to happen on a scheduled basis late at night. There is a confirmed wifi connection (in my garage). Several previous updates happened without a hitch.
Thanks!
