Missing Promised Features/Software Bugs
kdryden99
Richard
Montreal Canada
Richard
Nissan Sentra Spec-V, Nissan Rogue, Future Infinite Blue Mach E
  • Thread starter
  • Thread Starter
  • #16
To me, instrumental display electrical whining and wind noise from glass roof are the two biggest issues. Surely everyone has different priorities.
Ford may be able to tune it. But I don't think it's realistic to expect it to work much better. I think there are technical restrictions there. If you expect it to work as well as key fob, you will be disappointed.
I refuse to carry keys, and would be fine using PIN code to enter and drive exclusively. (I use Nest x Yale lock for home, which can be unlocked with either PIN code or through a button in app. I use PIN most of the time, because that's faster than unlocking from the app.) PaaK is more convenient than using PIN code, but I don't mind falling back to PIN code. So PaaK has met (or exceeded) my expectations.
  • For entry, PaaK works reasonably well for me.
  • For starting the car, the car often can't detect PaaK when the phone is in my pocket when I sit in the driver seat, which reminds me to put it on the charging pad (and therefore isn't too bad).
Android Auto is fixed, if you are tech savvy enough to install the next version before Google rolls it out to 100%. If not, well, multiple people including me have verified that the next version works, so all you need to do is wait a week or two.
Works perfectly with my 2012 model LiftMaster. If your garage door opener is very old, it is well known that HomeLink may have compatibility issue with it. There really isn't anything Ford can do here. You may be able to buy a bridge that would resolve your issue.
Do we have an issue page? If not ill change my title and add the whine and wind noise. As for the garage door unless we have more data on what you said, ill leave it. As for wireless AA, if you have to go find a beta release to get it to work and not as simple going to playstore and updating it, it also stays.
As for Paak youre probably right but thats not what was promised so it stays.
Advertisement
kdryden99
Richard
Montreal Canada
Richard
  • Thread starter
  • Thread Starter
  • #17
Also once these issues are resolved i will put them as resolved with the date and a link to the fix if there is one.
JellyBelly
Kris
Kris
MME RR FE
I cant really add those since therent really promised, i understand what you mean though but I want to only mentions that were explicitly mentioned
Rear ambient lighting was promised or ambiguous but based on main screen showing rear lights we can imply promised 😂
JellyBelly
Kris
Kris
MME RR FE
Yes there is an issues page
Badger_Prof
Randy
Randy
I want to make a list of features that were promised but not working or not available
THE FOLLOWING HAVE BEEN WORKING RELIABLY ON MINE:
WORKS-Paak (needs work, doesnt work or too sensitive)
WORKS-WiFi connectivity (needs work, seems very picky with ssid)
WORKS-Door Capacitor (unverified)
WORKS-Automatic Profile from Drivers Seat (not working)
WORKS-Garage Door Opener (loses connection)
I USE APPLE CAR PLAY. WORKS GREAT-Android Auto (waiting Google fix)
WORKS-12V charging while plugged (unstable, needs work, doesnt charge properly )
HAVE NOT TIRED-Charging Schedule (needs work, issues with locations, very limited options)
HAVE NOT TRIED-Pre-Conditioning (limited options)
HAVE NOT TRIED-Charging Curve (needs wor)
WORKS-Charger compatibility (Charging stops on fault or very slow)
HAVE NOT TRIED-Charger payment (often fails)
DID NOT KNOW THIS WAS PROMISED. WOULD BE VERY NICE THOUGH-Frunk Open with FOB or Phone
DID NOT KNOW THIS WAS PROMISED-Rear ambient lighting
Anything else? please chime in will update
JellyBelly
Kris
Kris
MME RR FE
I would add imperfect plug and play with EA and difficulty connecting to connected services
Jako607
2019 Bolt
If we're adding bugs, my SiriusXM favorites don't all stick. After the other profile is used and I switch back to my profile next time I drive, only some of the 4 rows of favorites I set up are still there. Some spots are duplicates of other channels and some spots are now blank
burtonhen
Will
Will
SB Mach-e Premium AWD
This might be a dumb question but I’ve never purchased a car with only one fob. If I need a second fob for my wife, how much does that run me?
Ford may be able to tune it. But I don't think it's realistic to expect it to work much better. I think there are technical restrictions there. If you expect it to work as well as key fob, you will be disappointed. If that's what you want, use the fob (and buy a 2nd one if you need two).
JellyBelly
Kris
Kris
MME RR FE
Between 200 to 300 for most fobs from dealer. But no fobs available widely yet they are on back order and a few who purchased have not yet gotten them programmed as far I remember
kdryden99
Richard
Montreal Canada
Richard
  • Thread starter
  • Thread Starter
  • #27
kdryden99
Richard
Montreal Canada
Richard
  • Thread starter
  • Thread Starter
  • #29
kdryden99
Richard
Montreal Canada
Richard
  • Thread starter
  • Thread Starter
  • #30
wonder if this is also the issue with paak. Ill add it.
Advertisement
Advertisement
