Estimated range dropping off a cliff
macgyver60
michael
New York
Mach E Premium AWD Ext Range
I realize cold weather causes a significant loss of range but when I first got my Premium extended range MME the estimated range with 100% charge was over 300 miles. I know thats not very accurate but it stayed like that for months until around August when it began dropping off. As if today a 100% charge gives an estimated 179 miles of range. Its obviously colder now than it was in August but only a little colder than it was in April. I mostly drive the same 12 miles to work and back on local roads each day. Any idea why the estimated range is so bad now? I thought it was only supposed to drop by about 20% in cold weather
Murse-In-Airy
Chaumont, NY
Mach-E ER AWD
Nurse
30-40% loss in winter is typical. I bank on only having 2/3 my usual range. So from an EPA rating of 270 down to winter expectation of 180 miles.
Maldonado your GOM will be overly conservative. So while you may lose 1/3 of your EPA range, your GOM will guess even lower.
BMT1071
Glendale, AZ
21 MME SR RWD, 23 MME GTPE
Machine Control Specialist
Not sure where you heard 20%. When it gets really cold you're looking at ~40% or more.
Drive south and keep driving south until the range is more to your expectations.
macgyver60
macgyver60
michael
New York
Then you already know the answer. That and the GOM is just a guess and can be ignored.
I get that. The 20% estimate wasn’t matching what I was seeing so obviously that was wrong. The odd thing was that the numbers satrted dropping the end of August when temps were still warm but not hot so I was using less AC. I would think that would have helped the mileage
snowy_91
James
Aurora, SD
2022 Mach-E Ice Blue GT Performance
Why on earth if your commute is just 12 miles do you even care? I mean in the winter my current ranger drops from about 23 miles to the gallon to about 18, but with a short commute it is what it is.
Franchise
SoCal
2019 Outlander GT PHEV, 2021 e-tron premium plus
In Los Angeles that 12miles is a 1.5hr commute. ?
macgyver60
macgyver60
michael
New York
Thats my daily commute. We don’t all use the car just for work. I take it on ling drives occasionally too like anyone else
I read that northern states would see as much as 40% drop in range when it gets cold. I can't confirm that since I live in Arizona valley. Even here, I have seen the estimated range trend downward. I usually make note of the estimated range at 90% which is what I charge to most days. Here are those readings for a vehicle in the Phoenix metro area.
  • Late Sept 281-284 miles @ 90%
  • October 263-269 miles @ 90%
  • Nov 3rd: 274 miles @ 90%
  • Nov 15th: 263 miles @ 90%
  • Nov 23rd: 258 miles @ 90%
  • Nov 27th: 236 miles @ 90%
  • Nov 29th 7:30 am (51F): 226 miles @ 90%
  • Nov 29th noon (74F): 219 miles @ 90%
Really curious to see what happens tomorrow. Might drop into the 190s. If this is what I am seeing here in AZ then you guys up north must be freaking out. :)
macgyver60
macgyver60
michael
New York
Thanks for the data points. It was in the mid 30's most of the day here in NY (maxed at 42F) and 90% got me 198. I can live with this. I just wanted to be sure it was normal.
Could just be normal like you are thinking. Temp here this morning is 52F and I am seeing about a 22% drop in the estimated range display.
Jeffvisor
Harrisburg, PA
Ford Mustang Mach-e
I just got the 21p22 software update to my car and it improves the range on cold weather i was at 83% SOC going in and it showed 151 miles after the update dealer charged to 100 and it now shows 230 miles I am in 32 degree weather so a big boost. that is one of the fixes in this update it the cold weather drop off.
I still wonder if it actually increased the range (kWh/mile) or if it just increased what the guess o meter guesses.
The only way to increase actual range would be to somehow increase efficiency. Not sure how a programming change would do that. Gotta get the electrons from somewhere.
