Wondering About GT Extended Range Dropping
Neil4Real
I’m jealous, my Orange County commute is all hilly so I get 180 to 190 at 90% in the summer in my GTPE. Now, 145 to 160 lol. At least before the update that reset everything. Now it says I get 210 on 90%, but it’s slowly going back down lol.
redMachE22
redMachE22
Colins
Monterey Park
2022 Rapid Red Mach E GT
Every time, I drove up a hill at my kids' school ... I literally want to cry seeing my miles (display) going down.
Kabish
2021 Mach-E Mustang
Yup, once its constantly below 73ish degrees here in San Diego the MME displayed range will start to drop. Dunno why people try to differentiate between estimated range vs actual range during cold weather. Both go down, estimated range just typically goes down more so than the actual range you drive. You will also end up seeing a smaller hit in our late summers when its crazy hot.
BigMach-E
Bay Area
Mach-E GTPE Shadow Black 2021
Being that I’m in the middle of this Nor Cal winter, and I can’t charge at home for the moment, having to DCFC for almost every charge as of recent, with a standard battery, my commutes have been brutal.
62 F in my garage, 28 F outside. This morning.
Ford Mustang Mach-E Wondering About GT Extended Range Dropping Screenshot_20221214-073059_FordPass
AhardFSU
Antonio
Riverview
2022 Mustang Mach E
I feel like there should be a sticky notice at the top of this forum that says, ‘Your EV’s range will decrease in cold weather because the electrical reaction that is generated by electrolyte liquid that mixes with the lithium ion in the cells occurs at a slower pace when the weather gets colder. The electrical reaction factors into your range. Therefore, your range will be reduced in colder temperatures.
DR.J56
Texas
I had this issue also last year. I live an hour from my dealer so I figured I would diagnose the issue myself. Turned out I had an electron leak. Took me a while to figure it out but in March of this year I added some Stan’s No Tubes sealant I use for my bikes at the charge port. It worked till this November when I saw the drop again. I guess it dries up like it does in my bicycle tires and has to be refreshed every so often. I haven’t been able to add more but I plan to do so very soon.
So, I am from Los Angeles and this is where my GT extended range is charged. Before winter, at 90%, I easily get 260 miles out of a charge ... Of course that was during summer. The interesting thing is starting November, where the temperature in LA ranges from 43 low to 65 high ... Charging to 90% get me about 220 or less. Nothing change in term of driving habit or distance.
Is there anyone from Los Angeles that sees his or her charging went down significantly at this time of the month?
One more for the counter.
It's clear one of two things is happening:
  • During service your dealer swapped out the ER battery for the SR battery
  • One of your neighbors is siphoning your electrons
agoldman
Charleston, SC
My GT in Maryland sees well over 300 in summer. Todayat below 32 degrees it was still around 270. I only use heated seat and steering wheel and drive a lot with auto pilot. I do expect it to drop closer to 235 at its worst winter days, but I'm moving to SC and hoping for a bit warmer temps next month.
bshaw
Boston, MA
I don't know if it came to me via the Early Access program, or if its standard in one of the recent OTAs. But, the GOM range is alot more optimistic this winter. I was only down to about 220 at 90% when the weather hit freezing temps last week. (Previous winters would have shown < 200 for sure)
I noticed as I drove 3-miles, the GOM dropped by 6. I didn't keep following it, but guessing the ratio would have stayed similar, or at least higher than 1:1.
That makes the GOM actually less helpful than before, but I suppose its what people were clamoring for --- show the higher perceived range and complaints from customers will be reduced.
Update 3.6.2, which I got on 12/7. Updated DTE.
fpasta
Well, that confirms it. :). Thanks gals/guys for sharing.
Yup 85% was getting 200 mi. In warm weather. Colder weather 85% I was getting 185 mi, now 160 mi.
Bay Area Ca, RWD SR
