hybrid2bev
- Dec 4, 2019
- USA
- 2021 Job 1 Premium4X - EAP Member
I think the Mach-E actual EPA range numbers will exceed the targets. The current EPA targets are the 'at least' number that the actual EPA numbers should be. I wouldn't be surprised if the actual EPA numbers are 5% higher than the targets.The engineer said that Ford was being conservative with the range and that the Mach-E's performance was basically scary fast (enough so that guys who drove GT350s were intimidated).
If 270 & 300 miles are the stated range for AWD and RWD, respectively, what do you think the actual EPA will be? Will the EPA range be on-target, low or high compared to real world?
But for real world range, like any vehicle, it depends on how you drive. For example, my C-MAX Hybrid is rated for 38 mpg combined, but in the summer I usually get closer to 54 mpg and 47 mpg in winter.
