Faint burning smell while charging?
bellyer
'21 MME FE & '23 F-150 Lightning Lariat ER
For the past couple of weeks, when I enter my garage while my MME is charging, I am noticing a faint electrical burning smell. I am using a Grizzl-E standard EVSE set to 40 Amps for charging. I cannot tell where the smell is coming from. It does not seem stronger from the charging point on the car or from the EVSE itself or along the cable. Has anyone else noticed any kind of burning smell while charging? I have absolutely no idea where it is coming from, but it only happens while charging. I haven't noticed it elsewhere while charging, but I am usually outdoors when charging anywhere else. I definitely don't want to burn my garage down or damage the car.
DR.J56
This could be anything from the wiring to your plug plus all you mentioned. May need to start with an electrician and go from there. Definitely not good.
JCHLi
Turn off breaker, call electrician.
Likely will just need to replace outlet...
bellyer
bellyer
Before I had the Grizzl-e, the Ford mobile charger would occasionally get an amber light on it and stop charging the car. No idea if it could be related, but now I'm wondering if there could be a bigger issue with the install. Oh well, I will have an electrician out to take a look! Thanks again!
JoeDimwit
Waterford
Grabber Blue First Edition
Electrician
When they replace that outlet, and they will replace that outlet, tell them you would like a commercial grade outlet. They have better components in them and they aren’t much more expensive.
This ^^^^^
clsmooths
Cary
Mustang Mach E GT performance & Premium ER RWD
Assistant manager
For the past couple of weeks, when I enter my garage while my MME is charging, I am notocin a faint electrical burning smell. I am using a Grizzl-E standard EVSE set to 40 Amps for charging. I cannot tell where the smell is coming from. It does not seem stronger from the charging point on the car or from the EVSE itself or along the cable. Has anyone else noticed any kind of burning smell while charging? I have absolutely no idea where it is coming from, but it only happens while charging. I haven't noticed it elsewhere while charging, but I am usually outdoors when charging anywhere else. I definitely don't want to burn my garage down or damage the car.
Go on YouTube and search for this video, great info. I'm sure a lot of Mach-E owners have watched it, but yes a Niema 14-50 outlet is what you need.
Ford Mustang Mach-E Faint burning smell while charging? Screenshot_20220303-204935_YouTu
JCHLi
It's possible. It may have had the amber light due to a poor connection.
Now that it's unplugged, do it look like the plug itself was corroded or "burnt".
Composer
Andreas
Sweden
Ford Mustang Mach-E 2021 AWD
Music Composer
Scooby24
Olathe, KS
'25 BMW i4 M50; '25 MME GT
Healthcare IT
