tonesto7
tonesto7
Anthony
Ann Arbor, Michigan
2021 F150
I’d still like to be able to see the odometer on the medium and large widgets.
There seemed to be an unknowable limit to the widgets and their content. It prevented the widgets from displaying or refreshing.
The odometer is on the main page of the UI and on the medium (simple) widget.
I can attempt to add it back to the large widget and see if it causes issues.
ktn
Current: F150 Lightning SOLD: 2022 Mach-E Premium ER AWD
I can absolutely add that.
Try using the widget tool to force the script to download.
You should now see version 2022.05.04.2 which includes the 12v on the main page.
Working great now! Nice update
I vote for the odometer coming back to the medium detailed widget if it doesn’t cause issues.
IgorKl
Pacifica, ca
'22 MME CaliRoute 1 AWD and '25 MME Premium RWD Ext
Does widget support multiple MMEs for the same FordPass account?
tonesto7
tonesto7
Anthony
Ann Arbor, Michigan
2021 F150
Does the widget support multiple MMEs for the same FordPass account?
It does... Just use the Widget Tool that you used to install to create a second instance
tonesto7
tonesto7
Anthony
Ann Arbor, Michigan
2021 F150
Believe me, I would like to. Just the thought of tinkering with the layout again might induce PTSD.
I spent an hour trying to add it yesterday and it screwed up the entire page alignment :(
The best I can do right now is to say just tap the widget and view the milage in the Widget Main page.
No worries. Thanks for trying!
I'm looking for anyone who has any pending OTA updates or data showing under the OTA data info that's not expired.
I gave one pending according to the json data. Still can’t use the widget though.
tonesto7
tonesto7
Anthony
Ann Arbor, Michigan
2021 F150
If you are running the latest version open the widget UI > Menu > Settings > Reset Login/File Options > Reset everything.
You will need to exit the Widget UI and reopen to be prompted to enter your info again.
This should allow you to start over fresh.
I’ll give that another try a bit later today.
At this point neither scriptable nor the widget are on my iPhone. And yes, I tried it from a fresh installation of scriptable as well in the past. None of this (or the other suggestions made) has worked since the widget stopped working after 2.5.1 was delivered.
tonesto7
tonesto7
Anthony
Ann Arbor, Michigan
2021 F150
I'm detecting contradictions > You mentioned that you shared the OTA data with me which requires the widget and now you say you don't have scriptable or the widget installed!
You also keep mentioning 2.5.1, but that will have had no effect on the data that's output from the vehicle. So your issue lies elsewhere in your account or the widget itself.
Just to be clear @tonesto7, I’m aware that starting from a fresh script should give a proper widget. But it hasn’t worked. What I haven’t done is reinstall scriptable and try again. Ive learned to live without the water diet and just use json data when I’m curious as to OTA data. I’ll let you know what happens.
All in the past tense. Subsequent to all the various suggested fixes in this thread, I deleted the widget and scripts and started over. Many times. I did the reset. After about 10 days of that I just deleted everything haven’t bothered with it since. And no, 2.5.1 didn’t cause this but the widget did stop working quite literally right after 2.5.1 was installed.
I have some farm animals to attend to when it’s light here. I’ll download scriptable again and give it a try after that.
