Ford's Connected Charge Station
eastern refugee
Rich
california
insurance agent
He set it up so it has its own breaker. He said something about having to pull new wires. the house was built in 2009. Not sure what he meant.
eastern refugee
Rich
california
insurance agent
I'm not sure but I think the Ford Wall box does not come with a plug. It is designed to be hardwired to a breaker in your power service box. Also, it can output 48 Amps which requires a 60 Amp breaker so you would have to turn down the output on the EVSE which kind of defeats part of the expense of getting the wall unit.
So I need to change it to a 60 and I will be fine??? This sounds stupid but I am not electrically inclined. Since it has its own breaker and 240 box. he can just lose the plug and hook it up directly to the wires???
larryjwhite
Larry
Bremerton WA
Honda Clarity
Maybe, it depends on whether he used wires that are only rated for 50 amps or if he used wires rated for 60 amps or more if he used heavier wires that can handle 60 amps its fine, otherwise he will have to replace the existing wiring to handle the extra load.
eastern refugee
Rich
california
insurance agent
Thank you EVER so much for answering my stupid questions.
Billyk24
William
PA
AS for HVB battery stress, below 20% soc and above 80% soc is what one wants to minimize. Meaning don't charge to 100% once you get home and let it sit all night at this level.
Ford Mustang Mach-E Ford's Connected Charge Station tesla battery stress and soc
eastern refugee
Rich
california
insurance agent
In the fine print you can finance at the time of purchase both the ford hard wire charging station as well as installation.
Billyk24
William
PA
I have a 50 amp 14-50 240 volt outlet installed in my home. Meaning it should be good for nearly 30 miles per hour of charging.
schmluss
Russell
Redondo Beach
Mustang Mach E Premium
Same here, built the house with the 14-50. Currently have a Juice Box for my Niro plug-in. Will use it for the Mustang too.
eastern refugee
Rich
california
insurance agent
Is the 14-50 the same as a dryer outlet???
eastern refugee
Rich
california
insurance agent
So it sounds like the one I have. Thanks.
Plenty of receptacles have prongs on all sides. Here's a NEMA 14-30: http://www.theelectricbrewery.com/i...-wire-dryer-receptacle-outlet-NEMA-14-30R.jpg
Be careful, and check with an electrician if you have concerns about your home's readiness for higher speed charging setups.
My understanding is that the EVSE supplied with the Mach-E will come with two adapters: NEMA 5-15 (the most common household style 120V connector) and NEMA 14-50 (commonly available at some RV parks and for electric ovens in a modern kitchen). Even though it will have these adapters, the charging rate will be configurable to give you some flexibility for it to work with your home's wiring and other loads that might share the circuit. The maximum charge rate on the included EVSE is 32A @ 240V, which is considered safe as long as your wiring is appropriately sized for a 40A circuit and nothing else is using that circuit at the same time.
