FORScan MME spreadsheet
What about 2024s? I did the same thing when I had my Bronco and could see if there's an amber on always DRL for the 2024 Mach-E
The DRLs on the 2024 are integral with the turn signals. They are white until the turn signal is active then they are amber. ??
Nomad77888
Alan
Miami
2024 Ford mach-e
Thank you, this saved my sanity. The chimes were really loud coming through the speakers. I also changed the chimes to only play through the instrument cluster.
Elar
Peter
Hungary
Hello
Propulsion sound : Can i turned up (or just turned off)?
LaFong
LaFong
Colorado
Mustang Mach-E GT 2024 Vapor Blue Metallic
Systems Engineer
Hello
Just turned on/off, there is no volume setting for it.
UN1075
2021 Mach E Premium Extended
Well everyone it’s story time…
I have 2021 Premium, since I got it in January of 2024 I have not had blue cruise available. After 5+ trips to the dealership, hours on the phone, countless follow up calls and tickets…still no blue cruise (escalations, TAC team, regional managers…nothing). It’s never showed up in my connected services, and never activated in the car. So I was connected with @rugedraw and my adapter arrive tomorrow to change literally 2 things in FORscan. Being part of this community has been great and my passion for modding cars and tinkering with things has been reignited. I just want one of the main reasons I got the car to just work…
So eager to see if this does work. Will update everyone tomorrow and share everything at that time for what I did to fix my problem.
Sorry for asking a question about a reply from months ago. I just picked up a 21 Premium Extended a few days ago and I'm having the same issue. Can you elaborate on how you fixed this? BlueCruise isn't an option in my connected services. I'd love to know hit to fix this.
rugedraw
Javier
Miami, FL
Auto Sales
Welcome to the forum. It's not really a one-size-fix-all kinda thing. Message me the VIN and I'll take a look to see if I see anything that will help. Not everything is easily fixable, but everything is fixable.
UN1075
Thanks so much for the quick reply! I just sent you a direct message with my VIN.
I wasn't sure if it just wasn't available in my area (Florida) but I'm seeing in here people in Florida using it so I know it's not that now. This is my first EV so, all new to me!
rugedraw
Javier
Miami, FL
Auto Sales
Got your message. The config on your car is correct, so whatever is causing your BC not to work is not the same issue. That guy had to use FORScan to change his IPMA config from what he had to this:
Ford Mustang Mach-E FORScan MME spreadsheet 1736298828462-lm
Above is what your car shows already which is correct for your car. I'll message you so we can look further into it off the forum since whatever the fix entails, it may have nothing to do with this thread.
Does anyone know if there is a parameter setting to enable the power LED on a 2024 if a 2021-2023 Start/Stop switch is installed? ??
Gullwingdmc
Chip
Boston, MA
Is there a list of common things you can change?
I’ve tried looking through the spreadsheet, but there’s a lot of acronyms and numbers to wade through.
LaFong
LaFong
Colorado
Systems Engineer
The F150/Lightning spreadsheet has a Common tab, perhaps we should get similar added to the Mach-E version.
F150/Lightning Sheet
Note that it is possible for the module address to vary between those two and the Mach-E. If you are editing a module manually, double-check that the module address is the same.
Gullwingdmc
Chip
Boston, MA
Something like that would be really useful for a FORScan beginner (like me). I have found the various posts across this forum that reference the common changes, but the search on here is not great and the labeling of posts is not or miss, so I’m sure I’m missing some.
Maybe we could create a form where Pepe could submit their favorite mods and then add those as a tab to the Mach-E spreadsheet?
I’m thinking things like
- enabling the GT power meter
- tilt down mirrors on reverse
- temp on the IPC
- disabling the snowflake/cold icon on the IPC
LaFong
LaFong
Colorado
Systems Engineer
The current sheet comes from Livinitup, who also did the F150/Lightning sheet. He has access to the Ford stuff that the rest of us don’t. If you wanted a living document, we might have to do a separate one. I could start one. I worry slightly about general public edit access. I suppose we could do a native forum table in a new thread, but I can’t see how to do multiuser editing.
