Grizzl-E mounted upside down?
Scott H
Scott
Westlake Village, CA
2018 BMW i3 Base, Mach-E4x - Inf. Blue (ordered)
I'm installing a Grizzl-E EV charger with a Splitvolt Splitter Switch plugged into my dryer outlet.
The NEMA 14-50 outlet on the Splitvolt is upside down. And the plug on the Grizzl-E is so short that I would have to mount the Grizzl-E upside down below the Splitvolt.
I would not want the Splitvolt upside down, because it has digital readouts for current, voltage, and power that would be upside down.
I recall seeing a picture of a Grizzl-E mounted upside down, but I can't find it now.
Has anybody mounted a Grizzl-E upside down?
Garbone
Gary
Loafer
No. But mine is currently wrapped in an old white dish towel to protect it from the sun..
Ford Mustang Mach-E Grizzl-E mounted upside down? IMG_20210305_182355
Scott H
Scott H
Scott
I could replace the Grizzl-E plug with a longer one. Or buy an extension cord. But I'd like to avoid doing either of those things if possible.
Murse-In-Airy
Chaumont, NY
Mach-E ER AWD
Nurse
Upside down wouldn’t be any problem. I’ve opened mine up to change the dip switches and there is nothing inside that is loose. So upside down won’t matter.
phidauex
Colorado
Renewable Energy Engineer
Agreed, as long as it is indoors, then orientation shouldn't matter. Outdoors the strain relief fittings wouldn't like to be on the top of the unit for an extended period of time.
Scott H
Scott H
Scott
Well, I wound up installing them side-by-side, but I think upside down would have been fine in my garage. Now, if only I had an EV to charge...
Ford Mustang Mach-E Grizzl-E mounted upside down? Grizzl-E mounted no dryer plu
RockwallRick
Lake Wales, Florida
22 Ford Maverick FX4
So has anyone mounted the Grizzl-E upside down? I have been thinking about this after taking a closer look at my Nema 14-50 Milbank Power box in my garage.
Ford Mustang Mach-E Grizzl-E mounted upside down? 596E2C73-B199-4E67-888D-8EA459CB95EB
Tony.T
Tony
Bodmin uk
Toyota C-HR sadly gone, MME RWD ER now with us!
Well I was told not to mount my charger upside down in case the electrons fell out...... ?
(sorry- Brit humour!)
mccdeuce
Millersville, MD
2019 VW e-Golf, 2022 MME Cal RT1 IBSM
That’s very funny but can anyone think of a good reason why this would not work out?
There is no reason you cannot mount it upside or sideways or however you want as long as you manage the cables properly so that there is no pressure on the strain reliefs - and the GrizzlE strain reliefs are pretty solid.
RockwallRick
Lake Wales, Florida
Thanks for your reply! My plan is to mount it upside down below the Milbank box shown above so the 14-50 plug will have a straight shot to the outlet.
Logal727
C
Yeah should be fine as long as it’s not a crazy tension on the cords, gotta make it work somehow!
