Grizzl-E mounted upside down?
Logal727
C
ā€˜21 Carbonized Gray Mustang Mach-E Premium AWD Ext
The GrizzlE is now mounted upside down as planned. I wonder if my Wife will even notice? lol
Did yours come with the plug holder? I actually like that one a lot, as it allows the plug to move around in case it gets bumped.
JSW
Ann Arbor
Chevy Bolt; Porsche Boxster; Chevy Blazer; Jeep Wrangler
The only positional advice on charging stations I’ve received pertained to mounting them outdoors - apparantly some brands are weather-proof only when mounted in their proper orientation.
FWIW, my son borrowed my ford mobile charger for use with his Chevy Volt (until he gets a Tesla in a couple of years), and he mounted it upside down because it worked better given the existing plug. His garage was set-up for a Tesla by the prior owner and he didn’t want to swap out the outlet….
Ford Mustang Mach-E Grizzl-E mounted upside down? 6389ABB1-7032-4834-B570-7180C93A03E9
CHeil402
King of Prussia, PA
2017 Audi A4, 2021 MME
Electrical Engineer
Two notes... mounting it upside down indoors shouldn't matter, but as pointed out, I wouldn't do it outside based on the design to keep water ingress out (unless it's covered from rain/snow). Also, if you're mounting it in a garage, it should be installed higher up from the floor. The NEC is somewhat vague about garage outlets and things like that, but it should be "protected from damage", i.e.: a car can't drive into it.
RockwallRick
Lake Wales, Florida
22 Ford Maverick FX4
They claim its tough enough to drive a Truck over it! I decided not to use the hanger that came with it but I added a couple velcro straps to tidy up the cables. Wife STILL hasn’t noticed that it is mounted upside down! Lol
Stang68
Any negative experiences with it being mounted upside down yet? I just received mine and instead of turning the cable I may just mount upside down. Although the cable with the plug seems so beefy that I think it would handle the bend to the outlet!
Motomax
Max
VW GLI, 4Runner
There’s nothing in there that is affected by orientation, nothing.
the only catch is mounting it upside down Outside can cause water to pool around the connections and if the seal isn’t perfect it could leak inside.
Miav8r
Jon
SC
2023 GTPE
Or, you could rotate the receptacle in the box and mount it right side up.
Stang68
I’ve thought about doing that, seems like it’s as simple as unscrewing the plate and turning the outlet, but I’m not sure if there’s enough slack on the wires and I’d rather leave it the way my electrician installed it.
Have you tried rotating your own or had experience with that?
Miav8r
Jon
SC
2023 GTPE
Yes, I rotated mine. Should be plenty of slack in the box. Turn the breaker off first!
