Hitch install uhaul
21st Century Pony
Martin
Arlington, Virginia
I just attached pix in my post above.... folded (hidden) and unfolded and connected.
steve.panse
South FL
2022 Mach E GT PE
The Draw Tite Hidden Hitch (76919) is the way to go...although it is very expensive (~$600 for the hitch alone). It’s completely invisible unless the removable receiver socket is installed. I installed myself in about 2 hours. (No electrical, for bike rack only)
21st Century Pony
Martin
Arlington, Virginia
It all depends on how you want to use it.
The OEM hitch is altogether around $800, a little less if you can avoid European VAT. Plus shipping of course, which is another $200 or so because the assembly is pretty heavy.
The OEM hitch is also the strongest construction, from what I've seen. it certainly seems strong enough to pull the car out of a ditch etc. from the rear.
Its Euro swan neck is key-lockable and quickly attachable / detachable. The electric connector folds away.
It can tow and it can carry bike racks, but only Euro style bike racks that fit onto its swan neck ball - Thule among other companies sells these.
I went for the Euro OEM hitch to be able to pull my Mach E from the rear in an emergency, and to tow house utility loads on occasion... and to maybe tow a teardrop camper.
Mach E AWD technically accepts up to 3,306 pounds tow weight, and a 136 pound tongue weight for towing, and up to 175 pounds vertical hitch weight for a bike rack. I think some of these limits are dictated by the Mach E's mechanical design limitations, as my tow hitch Mach E installation instructions gave a tow strength of about 4,200 pounds for this attachment. This info is also available on other threads here so I won't repeat it.
And yes, the bottom of the rear bumper cover needs to have a cutout - shown in two of my attached pix above.
I think the best keywords to search the existing posts on the subject here are "Dutch" and "Brink". There are videos as well.
Hope this is useful info.
Killerkg
Kunal
Vienna VA
2021 Mustang Mach E Job 2
Finance
It's available from uhaul as well, I think it's $474 here in NOVA
su-ch+mache
carl
Germany
www.ford-suv-freunde.com
Escape MY17, Puma MY20, Mach E MY22 AWD ER TP2
retired buyer
I have that Brink on my MME as well.
really works very good, you don't even notice the trailer or bike carrier.
I had my dealer install it before I picked up my pony, costs were about 900 Euro.
In EU the electric is plug and play (drive). So installation take here just about 2 hours.
steve.panse
South FL
2022 Mach E GT PE
I think the construction of most hitches, at least the Draw Tite, is substantially beefier than the unibody rails it bolts to on the vehicle…hitch construction isn‘t my first worry. Sorry, but I prefer the universal 2” receiver over whatever that European ball-on-a-stick thing is (and my 4 bike Kuat rack requires it anyway).
21st Century Pony
Martin
Arlington, Virginia
Well... there is also the manner how these hitch frames tie into the vehicle. Pls see the attached pix in this post to see the Ford tow bar bolts into the frame rails with a steel L plate which sandwiches the frame rail between this L shaped insert and the corresponding L shaped tow frame on the outside of this vehicle frame rail. That's a pretty robust setup. For comparison, how does your Draw Tite hitch model tie into the frame rails?
That ball-on-a-stick and the North American square receiver are merely different ways to get at the same goal... I bet your North American (not quite "universal") receiver has another ball-on-a-stick thing on its end ;) and there is no reason that I see to feel sorry for our individual preferences. We are sharing potentially useful info with each other, and that is imho always welcome.
Of course, an already bought bike rack that fits the North American square hitch receiver certainly would tilt the decision.
I offered my info so others here can know there is a Ford OEM solution.
Ford Mustang Mach-E Hitch install uhaul Mach E OEM tow frame insert with 3 bolts
Ford Mustang Mach-E Hitch install uhaul Mach E OEM tow frame insert with 3 bolts - closeu
Ford Mustang Mach-E Hitch install uhaul Mach E OEM tow frame - assembled except for the electric connector
Ford Mustang Mach-E Hitch install uhaul Mach E OEM tow frame - data sheet with Ford label
Killerkg
Kunal
Vienna VA
Finance
I found this video on YouTube showing the draw Tite installation
Killerkg
Kunal
Vienna VA
Finance
Thanks for every ones inputs. I did get the hitch installed at my local uhaul. All looks good, great job done. Got my bike rack installed as well
kindofblue
Reid
Arroyo Grande CA
Grabber Blue Mach e Premium 11/5/22, '25 Lexus 45h+ PHEV
I just checked my Thule rack and the receiver bit would need to extend out farther or else the hitch would hit the bumper before the pin could go into the receiver. I'm aware of hitch extensions but would prefer to get a received that was far back enough to not need one and b)the shortest extension I've found is 6".
And no, I don't want to get another bike rack. Those puppies are expensive. Thanks for any suggestions.
MacherAWD
North Shore MA
Healthcare Software
Fyi I got the U-Haul hitch last week, also just ordered a 7in hitch extension, this way my trunk can open with bike rack on, $19 on Amazon.
kindofblue
Reid
Arroyo Grande CA
Pics please when you can.
